Vortech, need help!
Old Dec 27, 2006 | 10:54 PM
g's uppp's Avatar
Vortech, need help!
I just got my car re-tuned after I added the crawford plenum, btw, i have a vortech sc and i seem to be losing boost at 6500 rpm, what could the reason be for the loss of boost?
Old Dec 28, 2006 | 08:11 AM
booger's Avatar
Is it the newest cast plenum ? Or one of the older versions ?
If its the newest one , I would say you didnt get the gasket on right , or the rubber thing around the oil filler got caught in the plenum .
If its an older version . They have been known to warp when they weld them back together . Two or three gaskets have to be built up to make up for it
Either way....if you havent changed anything else....its a boost leak at the plenum
Old Dec 28, 2006 | 10:37 AM
g's uppp's Avatar
the car is also running lean after 6500...could it still be the plenum?
Old Dec 28, 2006 | 12:18 PM
booger's Avatar
retune it
Old Dec 28, 2006 | 02:03 PM
G2FAST's Avatar
whats your location..............maybe we can refer you to a good shop.......
Old Dec 28, 2006 | 02:22 PM
ISMSOLUTIONS's Avatar
It could be fuel pressure, belt slippage, a leak, or BOV diaphragm that is not good, etc.
What are you tuning on - the SS box or other?
Where are you located?
Old Dec 28, 2006 | 02:26 PM
Hi-TechG35's Avatar
Retune big time and check your compression
Old Dec 28, 2006 | 06:18 PM
booger's Avatar
You havent answered any ones questions . But finding a good shop to have the car checked out , was the best advice . You had it tuned after the install of the plenum . So Im going to take it that something has happened after the last tune . Take it back to the shop . It could be just that its colder out and its leaned out because of the extra air flow when cold .
seagrasser
May 3, 2022 09:43 AM
StreetStandard
Engine-Vendor
117
May 22, 2020 08:21 AM
n2fooz
Sep 4, 2015 07:46 PM
