Working on my motor pics...
Old Jan 10, 2007 | 05:11 PM
2slo2bfurious's Avatar
Posted this in the local forum, just wanted to post here for fun too. I figured I could have used these pictures to help while I was doing this, maybe it can help somebody else out!
https://g35driver.com/forums/florida-g-club/131383-working-my-motor-pics.html
EDIT: more on pg2
Old Jan 11, 2007 | 12:48 AM
zazaracing's Avatar
Team Transport Member
hey dude looks amazing great job....if you dont mind what did it cost you and how long did it take?
Old Jan 11, 2007 | 02:16 AM
G35BASTARD's Avatar
NICE! I second the above, if you don't mind us asking around how long did it take, and around how much?
Old Jan 11, 2007 | 02:40 AM
Slyding_G35_03's Avatar
yeah how long did it take u to build that? nice job man...
Old Jan 11, 2007 | 03:01 AM
nanjay's Avatar
Job well done.... Mind sharing your specs... with us?
very impressive job done at home....wish i had a garage.
Old Jan 11, 2007 | 03:50 AM
The motor is just a basic build:
Arias 96mm 8.6 CR
Eagle H Beam Rods
ARP hardware
OEM Bearings
Basic headwork (Valves seals, 5 angle cut, very mild P&P)
Cosworth/Cometic 96mm hg
Crank balanced and polished
Gasket overhaul kit
05 water and oil pumps
Total cost of build under 3500 including longblock core and machine shop labor, saved quite a bit by having a local machine shop bore and hone and assembling the longblock myself. I think fully assembled longblocks go for avg. 5-6k + core 2k...
And... ANYONE can do this with a service manual and the right tools.... took me about 1 week working on and off maybe a couple hours each night, and I'm slow, and don't have much skills....
Old Jan 11, 2007 | 05:42 AM
Audible Mayhem's Avatar
nice man, what did you use to seal the oil pan??
Old Jan 11, 2007 | 09:00 AM
Madelinot's Avatar
So, you had the machine shop assemble the short block (piston, crank, etc), right?
Good job!
Old Jan 11, 2007 | 04:37 PM
nanjay's Avatar
Good job!
i beleive he assemble it himself.
hey its not a race when your building your own block.... its how well you do it..
I have been comtemplating about doing this down the line, due to the fact assembling involves stretching the rod bolts and torqued to the right spec.
torque specs i have no problem with as I have done a head gasket on my jeep, but the head bolts needed retorquing after about 300 miles of driving, not alot, about quarter of a turn. Since you done it already whats the proper way to torque the main and rod bolts?
Old Jan 11, 2007 | 04:46 PM
Mark350GT's Avatar
looks incredible. what number you aiming for?
Old Jan 11, 2007 | 05:28 PM
Madelinot's Avatar
I don't think so. He says: "Freshly built shortblock back from the machine shop..."...
Old Jan 11, 2007 | 05:30 PM
Mark350GT's Avatar
no the machine shop simply machined the block not assembled it.
Old Jan 11, 2007 | 05:32 PM
My machine shop assembled the shortblock for me since they had to do the maching of the cylinders and crank anyways, I would have saved like 100 bucks if I did that part myself. But its just putting on the bearings and pistons rings then torquing down the rod bolts and main studs.
I'm shooting for 500whp once I'm done with everything....
Old Jan 11, 2007 | 05:33 PM
Mark350GT's Avatar
ah i c. nice
Old Jan 11, 2007 | 05:39 PM
TINMAN's Avatar
very nice...me likey
