0-60 times with Vortech?
Old Feb 28, 2007 | 10:21 AM
sentry65's Avatar
what are you talking about? 2002 911 turbos had 415 crank hp and weighed a little over 3300 lbs and did 0-60 in 4 seconds according to porsche
if you had enough power and traction you could get a G35 to do that too. The 911 turbo has traction and a rear engine as it's primary advantage
Old Feb 28, 2007 | 01:41 PM
darnelled's Avatar
It's not from Vortech, but here is a Motor Trend article with a Stillen SC 2003 coupe indicating 0-60 time of 5.5 compared to 6.3 stock.
http://www.motortrend.com/features/p...fications.html
Old Feb 28, 2007 | 03:48 PM
helldorado's Avatar
Speed magazine did a 350Z FI shootout back in 2005. The Vortech equipped Z was running Toyo Proxes RA1 275/35/18 rear tires (smaller than stock diameter by almost 1") so it had to shift to 3rd in the 0-60 test due to its 6560 rpm redline.
It did a 4.9 second 0-60. It probably would've been 0.2-0.3 seconds faster with a properly sized tires letting it hit 60 in second.
Old Mar 2, 2007 | 11:49 PM
rcdash's Avatar
The stillen car adds 70 hp they claim (I presume they mean at the crank) - that's say 55 at the wheels - must be stage I. 285 whp? A low to mid 5 sec time sounds reasonable for that.
With most bolt-ons you can get to that NA. I've had a Gtech-RR since my G35 was stock. My 0-60 times ranged from 6.2-6.6 secs. My 1/4 mile times were low to mid 14s. After K&N, hfc cats, 2.5 FI true duel exhaust, 3/8" spacer, my times are consistently 5.2-5.5 secs 0-60 and 13.6-14 in the 1/4 mile. That's with no weight reduction other than running with 1/4-1/2 tank of gas.
I've seen video clips of Stillen SC on G and Z cars running 12s. So clearly you can up the power. I think low 4s with a Stillen stage 4 and 3.9 final drive is spot on.
The problem with Vortech is the power is up in the high rpm band. Which means first gear launch is slow (relatively). That'll kill the 0-60 time even if the 1/4 mile is competitive.
Old Mar 3, 2007 | 01:45 AM
Deang35c6's Avatar
you must have an auto. With a six speed and rpm based boost you can launch the car at high enough rpm to get a good launch. However, I see low torque down low as a form of traction control. With the stock Vortech pulley and tune setup, you are making stock torque and horsepower (230 rwhp/220 ft/lb) as low as 4k rpm. My best 60' while N/A was 2.0.
On one chilly night, I smoked a M3 six speed to top of second gear, so 0 to 60 of 4.9 sounds about right even though 0 to 60 is only half the story
Old Mar 3, 2007 | 02:00 AM
Skaterbasist's Avatar
Retired SuperMod
Traction has always been an issue with charged G's.
That's why, unless you have some pretty good wheels, I've always believed the times they get for the 1/4 miles stray away from reflecting the actual power of the vehicle.
Old Mar 3, 2007 | 02:07 AM
Deang35c6's Avatar
So true. That's why I'm paying more attention to trap speeds than anything else. A tuned 8 psi Vortech can trap 108 to 110, so that pretty good considering 98 to 100 stock. If you take a look at the trap speeds of some pretty fast cars, you'll see how it fits in.
Old Mar 3, 2007 | 07:19 PM
booger's Avatar
There will always be a huge gap on 1/4 mile times from track to track . A 13.2 at 108 might be a 12.6 at 112 at a diff. track . Just like Dyno's , my 430whp might be 490wp on a different dyno . And someone elses 470wp might be 390whp on my dyno . So why even bother .
And to add...Unless your all on the same tires and at the same track at the same time . Comparing doesnt work
Old Mar 3, 2007 | 09:14 PM
Chrlesmd's Avatar
+1...
Old Mar 5, 2007 | 02:17 PM
ShAdY908's Avatar
my 06 6mt APS ST did a 12.5 on street tires .. dyno'd at 420rwhp/ 370ftlbs
my 0-60 was not the most impressive probably 4.8 ish.. I drive an STi now and its 4.5 and its deff faster 0-60 than my g was. its past 60mph that the g was amazing.
Old Jun 26, 2018 | 05:38 AM
Angstromm's Avatar
This is a pretty good tool for getting an idea of expected 0-60 times. If you run the calculator against know times, it's in the ballpark, generally:
0-60 mph Calculator for Cars
Old Jun 26, 2018 | 12:18 PM
onevq35de's Avatar
[QUOTE=Skaterbasist;1680880]"0-60 Times arent important when it comes to FI."
Dumb statement.
Old Jun 26, 2018 | 12:27 PM
onevq35de's Avatar
Better tool. Scangauge.
60', 0-60, 1/8th, 1/4, etc. Accurate to within 2/10's in the quarter verified by me at the drag strip. Lots of info on my thread link below.
https://www.infinitiscene.com/thread....230572/page-8
Old Jun 26, 2018 | 08:33 PM
philbegas's Avatar
It's sort of disappointing that you spend so much money and time working on the car at the expense of reliability and daily driveability and you end up with a barely faster car. Just save your money and get a pony car if you wanna go from 0-60 fast
Old Jun 26, 2018 | 08:47 PM
  #30
onevq35de's Avatar
That's a really generalized and vague statement. Sounds like your frustrated phil. One can sink $10k into a g or z and if done correctly will be in the 10's.
One need not spend "so much $". I went from 7.1 0-60 to 5.0 0-60 and from a 15.5 1/4 to a 14.0 naturally aspirated and on the stock block. Big change for my 2003 FX35. I've really enjoyed the process of researching, learning and executing and would say my FX is also more reliable than before I started. If all one wants is a cheap form of speed, yeah, american v8 for sure.
