Supercharger or Turbo???
Old Feb 10, 2007 | 09:04 PM
FrankPark's Avatar
Im going to be buying a 03-04 G35 coupe this summer, And looking into getting FI, so with the car being a Automatic and it will be an everyday car, what should i go with, i would say a Supercharger, but you guys know more than me.
Thanks.
Old Feb 11, 2007 | 10:16 AM
sentry65's Avatar
well, IMO if you have an automatic, a vortech SC or ATI SC is a nice setup, because as soon as you put your foot down in drive mode, the car downshifts automatically and you're up in the high revs making high boost.
If you had a manual, I might be more tempted to say get a turbo kit or stillen supercharger where you might be more likely to feel the lower rpm torque
Old Feb 11, 2007 | 11:45 AM
FrankPark's Avatar
I see, thanks.
Old Feb 11, 2007 | 12:11 PM
Chrlesmd's Avatar
It all depends what you're looking for and how much $$ you're looking to spend. I have a stillen kit on the way, and imho, it works for me because the stillen kit gives you immediate response, although it does die out up above 5-6k rpms. Plus, as long as you stay conservative, you don't have to upgrade other parts of the car, ie: engine internals, tranny, fuels, exhaust, etc.
Old Feb 11, 2007 | 12:49 PM
sentry65's Avatar
thing to be aware of, is the vortech and ATI superchargers out of the box are going to be pretty noisy and make rattling sounds unless you get your idle raised enough to get everything spinning fast though to kill the noises.
turbo will work fine as long as it's tuned well, but it's a little more tricky to dyno automatics from what I hear, even in manual mode they get weird dips and whatever in the turbo dynos i've seen so it could be trickier getting everything fine tuned. A SC would probably be easier to tune on an automatic, but you can get any setup to work if it's done right
Old Feb 11, 2007 | 02:35 PM
fomula1racer's Avatar
with all these chrgers and turbos are there any other mods anyone has to do to the engine then getting the charger placed on or stock oem stuff can handle the chrgers on the cars like brakes and pads and rotters and brake lines does anything else melt i mean chargers are what 5 6 g's what about other parts are they necessary or you need the chargers and thats it let me know
mike?
Old Feb 11, 2007 | 03:16 PM
FrankPark's Avatar
well ive been looking at a Vortech,with a valve body for the tranny, a intake spacer, or new plenum,dc headers, full exhaust,plugs,wires,ground kit.....ect just bolt on stuff, will that be good?
im only looking for like 350 hp, and 13's on a everyday automatic car, is this possible. thanks guys.
Old Feb 11, 2007 | 03:18 PM
Chrlesmd's Avatar
That's definately true, but there are guys who have blown their engine w/ simple bolt ons or just moderate FI. I don't understand why some guys can run high hp/tq numbers w/out problems, while others end up blowing their engine. Most don't have a problem, which is a good thing.
I was considering the Vortech too, but it's my understanding that it really doesn't give you much below 4k rpms. From 4k up to redline, it just hauls. Being that I have an auto, I decided to go w/ the stillen kit since it gives you more usable power in daily driving imho. However, as Sentry can probably tell you, w/ smaller pulleys, exhaust, ect, you can get way more power out of the vortech than the stillen.
Old Feb 11, 2007 | 04:43 PM
superchargedg's Avatar
valve body would be a good choice,intake spacer also(but not with the stillen).if you go vortech or ati the exhaust,headers would be a wise choice(but not with the stillen).we dont have plug wires and you have to go one step colder on the plugs.grounding kit is more for looks then anything....but my trans does shift faster with it.
Old Feb 11, 2007 | 09:13 PM
FrankPark's Avatar
hmm so you think stillen over vortech for everyday use and non valve body?....only thing is i gota buy a hood for the stillen, and well im not down with that but, hey if you gota buy it, i guess i will.
thanks.
Old Feb 11, 2007 | 09:37 PM
sentry65's Avatar
hehe you're all over the place with going back and forth, i'd really read lots more about the kits and people's impressions before making a quick decision. You'll be glad you did instead of getting something and finding out things you weren't expecting
Old Feb 11, 2007 | 11:03 PM
Chrlesmd's Avatar
+1...
Old Feb 11, 2007 | 11:04 PM
Rphillips6487's Avatar
from what ive heard sc is safer as apposed to turbo and is less expensive
hope that helps
