FI Oil Consumption
FI Oil Consumption
For you guys who are boosted, do you find yourself topping off the oil between changes? I checked my oil today and saw I was half way between the high and low mark. This never happen before I added the stillen kit. I know FI applications tend to use more oil, just curious to see what others are experiencing and how often you guys have to top off.
^+1
I added a spacer within the first two weeks of getting my G. Now with the spacer and greddy pan my car takes ~6.5qts which is nice for peace of mind in case I do go 0.5-1qt low, there is still enough in there.
I'm using a 5w40, full synthetic. I didn't think that a spacer was really necessary since I'm not pushing that much hp w/ the stillen kit.
Does anyone know, when you fill the engine w/ 5 qts, where does that reflect on the dipstick? Is it at the full line?
ive actually have never been more then 1/2 qt low at 3,000 mile intervals with mobil1.but now that mobil1 is not a true synthetic anymore...who knows.i have switched to amsoil now.
I didn't have any problems with burning oil when I was N/A, nor on the VQ in my Max. I've only had 1 oil change since F/I, so I'll have to keep an eye on it now. I'm also running Amsoil syn, and have stuck with the same 5w-30 I used before. Still unsure about whether I should go w/something thicker though.
