help with vortech belt!!!
Old Mar 17, 2007 | 01:39 AM
lastsongforagirl's Avatar
help with vortech!! main belt not cog
my main belt is skweaking like no other, took it off. re-tensioned the belts. and it just shouts at me. at idle its sometimes worse but as i speed up it just gets even louder, used belt dressing, and all else i could think of....pulleys are all alligned and everything seems fine........when i redress it, it shut up, but only for a moment then it starts again........now to the incident that started it. my brother sprayed the belt with a vintage belt dressing that he had laying around since he was born i think, but even then, seems like theres a sticky texture to the the belt. should i just replace the belt and clean the pulleys??? thanks
what size belt do i need and where can i get it ??? thanks
Old Mar 17, 2007 | 02:14 AM
imalazeeass's Avatar
check napaonline
Old Mar 17, 2007 | 03:33 AM
1illgt350's Avatar
gates belt 93.5 i think it is
Old Mar 17, 2007 | 10:07 AM
Brando's Avatar
Are you uning the 6 rib Gates/Napa belt or the crapy Gatorback? Get the Napa.
I loosened the idler pulley as far is it would go and squeezed the shorter 93 belt on with the stock pulley.....and never adjusted it in over 1 1/2 yrs!
Old Mar 17, 2007 | 12:35 PM
crappy gator back. i think ill be going with the napa
Old Mar 18, 2007 | 02:47 PM
booger's Avatar
Some people realy dont know how tight the serp belt has to be not to slip and squeal . Tighten up the belt more !
seagrasser
May 3, 2022 09:43 AM
Mad A
Not G35 Related
Dec 8, 2015 01:45 PM
NailBomb
Oct 28, 2015 07:53 AM
reaper76
Sep 20, 2015 11:59 AM
n2fooz
Sep 4, 2015 07:46 PM
