What Radiator For A Tt Setup?
Old Mar 23, 2007 | 01:58 PM
G-TWIN's Avatar
Question What Radiator For A Tt Setup?
for the next upgrade i was thinking in changing out the stock radiator for a better one. what do you recommend?
Old Mar 23, 2007 | 09:57 PM
urban's Avatar
Koyo is one which most people have.
Old Mar 24, 2007 | 01:07 AM
G-TWIN's Avatar
KOYO HAS A THICKER ONE FOR A 350Z. would this fit on the g ? will it hit?
Old Mar 24, 2007 | 01:15 AM
QuadCam's Avatar
I have no overheating issues on my G, but you could also ask TTrank. he just put a big 350Z radiator in his sedan.
Old Mar 24, 2007 | 01:39 AM
TurboTim's Avatar
We have a bolt-on solution so you can install the big 54mm Koyo into your G
Old Mar 24, 2007 | 02:19 AM
urban's Avatar
Tim would that still fit behind an APS FMIC or would it need some slight modification.
Old Mar 25, 2007 | 12:41 AM
TurboTim's Avatar
It sits behind the A/C condensor so your intercooler will be fine.We modify the 350Z Koyo radiator to fit the G. Plus you get rid of the cheesy plastic retainers that hold the stock radiator in and replace them with some stainless hardware
Old Mar 25, 2007 | 10:46 AM
Eagle1's Avatar
GTwin:
The Koyo, with some tweaks will fit on the 6MT. Here is a picture of the stock radiator and a Koyo side by side, so that you can see the difference the thick three core radiator brings to the cooling equation.
If you are running FI, this is a highly desireable modification, as is the introduction of either an oil pan spacer, or a deeper oil pan itself to increase your oil capacity. If you only street the car, that is probably fine enough. IF you track it, you need to upgrade the oil cooler to a bigger unit like the Setrab.
Old Mar 26, 2007 | 04:39 PM
G-TWIN's Avatar
Bump
Old Mar 26, 2007 | 08:49 PM
Madelinot's Avatar
Where can we buy this bolt-on G35 rad? Any Website?
Thanks!
Old Mar 26, 2007 | 10:08 PM
mraturbo's Avatar
We sell a custom radiator for the Gs.
M
Old Mar 27, 2007 | 01:22 AM
urban's Avatar
M
PM a price please.
Old Mar 27, 2007 | 01:48 AM
AboostedG's Avatar
Check out this one.
http://www.my350z.com/forum/showthre...light=Radiator
Old Mar 27, 2007 | 12:16 PM
mraturbo's Avatar
PM a price please.
PM sent or hit our website for contact.
Thanks
M
Old Mar 27, 2007 | 01:25 PM
Mark350GT's Avatar
the stock radiator and fans are ok unless you take your car to the track alot, in that case an upgraded radiator would be suitable.
