The spray debate
Old Apr 3, 2007 | 06:40 AM
Teamsr2k1's Avatar
The spray debate
So im debating on some spray for my 06 G35 5AT. any ideas guys?
Old Apr 3, 2007 | 08:32 AM
Chrlesmd's Avatar
I know there are a few guys here who have maybe a 50 or 100 shot on their G. Should be ok as long as you don't combine it w/ FI, at least on a stock block.
Old Apr 3, 2007 | 08:44 AM
papiloco21's Avatar
i recently did alot of research on this, check out zex, their products are pretty good and looks to be one of the most commonly used for the VQ's
Old Apr 3, 2007 | 09:09 AM
BracketRacerSteve's Avatar
I've run about 100-150lbs of nitrous through my NX wet kit at 75-shot, then upped it to 100-shot, only run 30-40lbs with that due to my year overseas.
I've had zero problems with the engine, I am getting a valve-body upgrade but that is leading up to FI down the road.
Just be sure to get a good A/F tune, I did mine on a dynojet and gained 100whp with a 100-shot of nitrous
Old Apr 4, 2007 | 06:29 AM
Teamsr2k1's Avatar
so do you think it would be safe to run 100 shot alot?
Old Apr 4, 2007 | 10:54 AM
Q45tech's Avatar
If the ultimate life of an engine is 300k [if properly maintained] my guess is that each 75-100HP shot for a quarter mile might stress the rings and bearings equivalent to 500 miles of driving or 10 cold crank startups.
A used car buyer should be very careful of any signs of Nitrous use as it takes life off the end game.
Dallsinghjr1
Sep 17, 2023 11:25 AM
prinny
Nov 22, 2015 11:07 PM
joeslates
Sep 11, 2015 11:19 PM
