Twin Turbo Installation
Old Jan 5, 2004 | 03:24 PM
mattycNJ's Avatar
My friend w/ a 350Z is purchasing the Power Enterprise TT setup. Does anyone reccomend a shop to install it in the New Jersey - Tri-State Area?
2003 G35 Coupe
6MT, loaded w/o nav., Diamond graphite, clear corners, injen intake, Borla exhaust, Unorthodox pulleys, Tein springs, Data Systems Grill, 20" Maido GR-5's on order..
Old Jan 7, 2004 | 10:26 AM
motoracer's Avatar
Re: Twin Turbo Installation
Where are you located in NJ? I have been using a GREAT guy in Pompton Lakes. He is very good with performance installations. I definitely recommend him. Let me know if you want his shop's number. Let me know how it works out.
Old Jan 7, 2004 | 09:40 PM
mattycNJ's Avatar
Hey moto
I live in Caldwell. Has your guy in Pompton Lakes worked on G35's/350Z's? If you could please give the the name of the shop & the phone #. Thanks
2003 G35 Coupe
Old Jan 8, 2004 | 01:50 AM
shivak's Avatar
I just have a quick, stupid question -- is the G35 still street legal with a SC/TT setup? Somebody in another thread made a remark like "with a TT setup the G is not street legal" - this isn't true, is it?
Old Jan 8, 2004 | 07:52 AM
motoracer's Avatar
The shop is called Unlimitied Auto Works in Pompton Lakes NJ. He has worked on my G a bunch of times, and does great work, and i'm not positive but he mentioned working on a guy with a 350z, but he has been working on cars and doing performance for years..he is real good. Let me know if you give him a call. I will PM you his phone number.
Old Jan 8, 2004 | 11:17 AM
JspecG35's Avatar
It depends if it's carb legal. I heard GReddy's kit isnt CARB legal yet so it won't pass inspection or something...but other then that they should be street legal
Old Jan 8, 2004 | 05:46 PM
Carlos3186's Avatar
yeah well for the other 49 states it is 100% legal asuming u keep ur cats.
<a href="mailto:Carlos3186@hotmail....otmail.com</a>
Old Jan 9, 2004 | 08:59 PM
Dabearz454's Avatar
There is a place in union that does good work from what i understand... ill check into that for you...
Old Jan 9, 2004 | 09:21 PM
GurgenPB's Avatar
Just a note - yI hope you ARE aware, are that you will not be able to turn up the boost passed 0.3 bar (5.X psi) without the TS ECU upgrade - which I stronly recommend. Send in your ECU to Danny and ask for the 7psi PE TT program. This way, you will be able to turn up the boost to 7psi on pump gas.... There is just NO other way to do it without endangering your engine...
Otherwise, as the kit specifies - you will need to use 100 ctane gas with anything passed 5psi up to 7.35 psi (0.5 bar) with the stock ECU - not a viable option...
Gurgen
<P ID="edit"><FONT class="small"><EM>Edited by gurgenpb on 01/09/04 06:22 PM.</EM></FONT></P>
Drifter2090
Dec 26, 2015 12:10 AM
DigitalDeviant
Engine - Intake/Fuel
22
Dec 4, 2015 10:27 PM
Team STILLEN
Aug 10, 2015 08:17 PM
