Greddy TT 5AT BOV = Stall?
Old May 21, 2007 | 04:04 PM
Jtrain's Avatar
I just found out my "compression surge" issue was due to the fact the guy who installed it disconnected my 200$ BOV because it was stalling.
I had him hooked it back up, thought because I was tuned it would fix it.
Stalled twice in 10 miles.
I was in DRIVE so that seemed like it might have had something to do with it.
But This is a really nice BOV, and sounds orgasmic, I would really like to keep it, But I wont if I keep stalling.... Do I just need to stay in tiptronic or what? I have attacted pictures of my set up just in case...
TIA
Eric
EDIT: I just called japtrix, They said that I should bring up the idle, but I've never honestly heard roger so confused!!
Attached Thumbnails Greddy TT 5AT BOV = Stall?-n70702205_30343734_7247.jpg   Greddy TT 5AT BOV = Stall?-n70702205_30343735_7534.jpg   Greddy TT 5AT BOV = Stall?-n70702205_30343736_7838.jpg   Greddy TT 5AT BOV = Stall?-n70702205_30343737_8139.jpg
Old May 21, 2007 | 04:12 PM
Jeff92se's Avatar
Red Card Crew
Is it after the maf? If so, it's discharging air the maf already counted. So the ecu gets confused and stalls.
Maybe you need an ecu tweak to whatever engine management you are using
Old May 21, 2007 | 07:53 PM
Jtrain's Avatar
Really? No one knows?
Old May 21, 2007 | 08:38 PM
2slo2bfurious's Avatar
Find somebody with a Cipher and have them bump your idle, or the dealership can too.... what injectors do you have?
Old May 21, 2007 | 08:53 PM
zackt69's Avatar
rarejdm.com
can you adjust that bov so it doesn't open under low boost? My 240sx was doing the samething until I adjusted the bov, now it's fine. As mentioned above the MAF is counting for air that is being expelled before it make it to the intake causing a stall, which in my case seemed to be a problem at low speed/low boost conditions - just my guess though, I am no expert
Old May 21, 2007 | 09:27 PM
ttrank's Avatar
Grocery getter
No it's pre-MAS by those pics. Still strange that you are having that issue. Try moving the idle up to 700-800 and see how that goes.
Old May 21, 2007 | 10:36 PM
booger's Avatar
Common problem ....your not getting enough air at idle . There is the JWT fix . Or some of us drilled a very small hole in the throttle plate .
Old May 22, 2007 | 02:15 AM
ttrank's Avatar
Grocery getter
Is that a 5AT problem. Have never heard of it on the 6MT. Not saying you are wrong or anything, just have not seen it before.
Old May 22, 2007 | 08:47 AM
booger's Avatar
I believe alot of guys have had it with return fuel systems and bigger injectors . Instead of bumping idle and or both can solve it most the time . It could be another problem..who knows with out being there . Just giving suggestions . And I dont believe it was a AT5 problem
Old May 22, 2007 | 02:00 PM
Jtrain's Avatar
Drilling holes obviously scares me. And Infiniti definitely wont raise my idle, The tech was like.... I could if it was stock, but I really dont know what to do.
And then it looked like he started doing math in his head and i said never mind. I was tought never to judge people, but im pretty sure there was a reason that guy works in a garage and not in a office crunching numbers.
So I don't really know how to raise my idle (on my 04)
EDIT: I haven't stalled in tiptronic.... at all ever, but drive owns me almost everytime... WTF
Old May 22, 2007 | 03:52 PM
NETSHARK's Avatar
its so simple just get a Cipher and you can bump it +250 RPM.
Old May 22, 2007 | 04:34 PM
QuadCam's Avatar
if the BOV is too close to the MAF (even if it is ahead of the MAF), it will cause issues. The MAF is very sensitive to turbulence, and having the BOV really close to it could cause a stall issue......
Old May 23, 2007 | 10:49 PM
Jtrain's Avatar
When I unhook it, it runs perfectly very smooth. It such a rough ride with it hooked up.
Can you tell from the pictures if it needs to be moved farther down?
Old May 24, 2007 | 07:58 AM
Audible Mayhem's Avatar
you need to raise the idle. it will solve it. find someone with a cipher.
could also be in the tune plus might be a vacuum leak somewhere...
Old May 24, 2007 | 09:40 AM
Jtrain's Avatar
Alright then, Thanks for all the info guys. I think japtrix has a cipher I'll swing by there. I doubt I have a vac leak, considering it works perfect without the BOV.
Thanks, ill let you know how it works out.
EDIT: I just called him and he says most '04 Z's dont comply with the cipher, however he hasn't really tried it with a G, So I'm going to go up there right now and give it a try.
