Oil Leaking Bad =(
Old Jun 16, 2007 | 04:20 PM
bigkrnxboi's Avatar
Oil Leaking Bad =(
3 days ago i heard extremely loud noises coming from my engine. I assumed my car was starving for oil. Since it was late, i decided to get some oil and put it in and later get an oil change. However after i put in the oil, there was a massive pool of engine oil coming from the bottom of my car. At first i thought it was because of an overfill of oil because i put in 6 quarts, but when i checked the pool of oil once again on my driveway and my dipstick which had very minimal oil, i am pretty sure something (a hose or an engine part) might be cracked/broken. Do any of you have any ideas of what might have happened?
Old Jun 16, 2007 | 05:44 PM
rcdash's Avatar
APS turbo on stock engine?
Well maybe... 3 days ago, you blew your engine and now the oil won't stay in.
C'mon, you didn't even mention you checked the oil level. And why would low oil cause "extremely loud noises"? Unless of course you broke something...
Old Jun 16, 2007 | 05:55 PM
GreenGoblin's Avatar
The goblin resurrection
get under the car and look for a hole
Old Jun 16, 2007 | 09:28 PM
urban's Avatar
Does not sound good, I would def. get under the car and look for the hole or should I say leak, could have a hole in the block which is not good.
Hope it's nothing major.
Old Jun 16, 2007 | 09:44 PM
rookie's Avatar
Isn't there an aux oil pump for the APS ST?
Old Jun 17, 2007 | 03:43 AM
bigkrnxboi's Avatar
yea i checked out it out. there is no hole. so i hope im good. BUT there is a leak coming from the inlet that goes into the oil pan. I towed it today to GTM. I hope Sam can work his "magic" again. Hes my hero =)
bigkrnxboi's Avatar
checked it out* <----im a retard.
Old Jun 17, 2007 | 11:22 PM
rcdash's Avatar
good luck man - hope it's something minor/inexpensive!
Old Jun 18, 2007 | 11:33 AM
mraturbo's Avatar
Sounds like a blown motor if you heard loud noises.
Goodluck.
Your FX look great...
M
Old Jun 18, 2007 | 12:31 PM
G Thizzle's Avatar
possible hole in filter... just crawl underneath and check it out bro!
JoeMac
Aug 20, 2015 10:17 AM
itztwinki3
Aug 11, 2015 05:52 AM
yassy
Aug 9, 2015 07:31 PM
newg37
Jul 26, 2015 09:32 AM
ClwMike
Jul 23, 2015 12:55 PM
