Joining the FI world!!!
Old Jul 15, 2007 | 10:51 AM
SouthernG35's Avatar
I am looking at purchasing a used TN kit from a local install and tuning shop. The kit was installed on the owner of the shops 350. The kit is a standard TN kit with upgrades like new 650cc injectors and brand new SN61 turbo instead of the TN 60-1. Being a FI newbie my question is about the turbo itself. Is this turbo comparable to the TN? Any difference in turbo lag or performance? Just wanted the experts opinion on this before I drop the cash on it. By the way he is asking 3K for the kit with the injectors. I have a UTEC already so engine management is taken care of.
Old Jul 15, 2007 | 11:00 AM
QuadCam's Avatar
I don't know what an SN61 turbo is........but you will need to buy a couple parts from TN to make the kit work on a G35. You will need a g35 spec A/C line from TN. the 350z has a different A/C line. also, you'll need a special inlet elbow on the turbo. otherwise , you need to cut a 4" hole through the front of the car, so that you can locate the air filter where the 350Z kit locates the air filter. It can be doen; I did it when I had my TN kit on my G35.
Also, go visit www.my350z.com; there is alot of good tecvh info on that sight. specifically, go into the forced induction forum.
Old Jul 16, 2007 | 09:48 AM
The SC61 is manufactured by Precision Turbo. Anyone have any info on this particular manufacture? I have searched online and it seems that a lot of 240 and such run these. Quadcam how much are the AC lines and inlet elbow from TN?
Old Jul 18, 2007 | 01:24 PM
ttrank's Avatar
Grocery getter
I think the A/C line is ~$100.
Like Andrew said, you can just cut the hole and use the 350Z intake. I made two holes like them to do make my new intakes. It would be like the one on the right.
Dallsinghjr1
Sep 17, 2023 11:25 AM
corynooooo
Sep 26, 2015 10:54 AM
