Best spot to hide your gauges on a G35
#227
#228
And Pivot speed meter in ash tray
upto 350km speedo
1/4mile time
Gforce accel and braking
Depo 4 in 1 gauge
Volt
Oil temp
Oil Pressure
Boost
- i dont know what the good or bad temp and pressure for oil is??? anyone?
TurboXS knock sensor and shift light (yes knock actually works..)
#229
Do you need to hook a wideband to the zetronix? or does it read the factory sensors?
I am getting too many gauges and I HATE the pillar pods I have 7 must have gauges and I would like to thin it out a little but I would also like a coolant temp gauge because i dont think the OEM one is right. With my big rad on the hiway the temps used to drop down to about 25% but now once the car warms up it wont move from 50% at all
#231
#232
Nice, i got same gauge.
upto 350km speedo
1/4mile time
Depo 4 in 1 gauge
Volt
Oil temp
Oil Pressure
Boost
upto 350km speedo
1/4mile time
Depo 4 in 1 gauge
Volt
Oil temp
Oil Pressure
Boost
#233
#234
LOL..I got the idea from your pictures and DIY thread. I PMed you about it before too.
What are you monitoring with the "USER P" input? Sorry I don't know normal oil pressure/temp either, hopefully someone can chime in with that information.
#236
Ideally I would want to have my boost guage and AFR Gauges tied into a HUD system of some sort...
Combing this http://www.dashtronix.com/Gauge_Projector_LIU8.php
with this http://www.ebay.com/itm/OBD-2-II-HUD...sories&vxp=mtr
has anyone done such a thing?
I dont know about anyone else... but when I am wanting to look at my AFR and my boost.... its usually when I am at WOT.... and at that point the last place I want to be doing is looking down, to the side or up lol.
#238
Yeah it shows up like in the two pictures, as a solid 392. That's the only thing I don't like about the Zeitronix, I wish I could change the EGT to display something else like TPS or RPM. But I still get up to three inputs (boost, afr, and choice of multiple pressure/sensor) on one compact display so it was the best choice for me.
#239
I have no turbo yet... been waiting on my parts for 8 months and still not been sent...
so none of the gauge sensors are hooked up except for oil temp and pressure.
User P i will try and get boost to hook up to the Utec boost solenoid.. i wont know if its compatible until i try .
As for EGT, yeah as you can see from the above there is no sensor attached, but a figure still shows up
And Lance, you have too much $, dam you and all your custom CF !!!
#240
Oh yeah about the bracket lol!
