Greddy Twins vs. Vortech...my comparison
Originally Posted by booger
http://my350z.com/forum/showthread.p...5&goto=newpost
hear is the other thread where your getting pounded...trying to make the same arguement there too .
Now I let you have the last word......another thing you seem to have to have...lol...some peoples kids....lmfao !!!
oh, did you mean the discusion? you know where people debate and talk about things? yeah that's what that thread is
Originally Posted by ttrank
Yes a 4psi Greddy is not that great when compared to a higher boost Vortech at high rpm. But who would ever run that set-up for any length of time? Lets see equal boost plots.
Then 15psi after tranny upgrades
Next summer is going to be fun. My car spent too much time at the shop this spring/summer. I'm definitely looking forward to next year
I'll give the nod to the TT setup from a dig, but from a roll, especially with a 6mt, I'll give the nod to the Vortech. This considers similar hp and torque numbers between the two. The vortech does much better with the manual tranny, because the driver can dictate what rpm he starts the roll-on race.
You really believe this? Same HP? SC and Turbo will never have the same HP/TQ #'s and don't you think Turbo with also 6MT can dictate what RPM to use? At 3500RPM a Turbo will already hit Full Boost and your Vortech wouldn't even hit half that boost
Please look at this thread.
http://www.my350z.com/forum/showthread.php?t=290095
Edit:
Granted from a roll there is a delay maybe .5 Sec for Turbo but within 0-800RPM the turbo will go from vacuum to full boost while your Vortech won't hit Full boost until Redline. Plus you can Brake Boost from a roll and once you let go of the brakes Turbo will already in FULL BOOST at any RPM
While this got sidetracked a little (nothing a little math can't solve), the original post was well-written and very informative. Nice job 617G!
Which tranny build did you choose (I assume you went with SGP or GTM)?
Originally Posted by 617G
Thanks. I've actually decided on a Edge racing TQ converter and a SGP VB first. If that doesn't hold up, then I will build. I think 450whp is the sweet spot for the street and once those components are upgraded I should be okay, but we'll see.
To the guy who posted that the Vortech would win from a roll if both had the same HP/Trq.....I have never seen a Vortech that can put out as much Trq as a TT even if both had the same HP, it just does not happen.
My Vortech had 440hp and 330Trq and my TT has 410/400, there is just no comparision even from a roll.
Originally Posted by urban
Good choice
jkeveryone with a turbo "feels" that their car is faster
they "feel" faster than modded NA vettes
I drove a stock STI once and it "felt" about almost fast as my car right when the turbo would kicked in, but I sure as hell know it's not actually faster than my car
IMO, if you were making 440whp with the vortech, but only 330 tq, then that probably isn't faster than a 410/400 APS TT car. It might be sorta close, but I'd give the edge to the APS setup in that race
what if your 410/400 APS car went up against a 475/440 tq vortech? That's the same % increase in power that 617G's vortech had over his 4psi greddy
Originally Posted by sentry65
I take it you have timeslips then to prove it?
they even "feel" faster than modded NA vettes
I drove a stock STI once and it "felt" about as fast as my car when the turbo kicked in, but I sure as hell know it's not actually faster than my car
Do not need timeslips when you have the same car to compare to.
You added a smiley whilst I was typing so I will be nice to you also
Missed you last comment about the race with your setup, unfortunately a man called Sam has my car and it will no longer be 410/400, we decided to drop compression and produce more power so I have no idea what it will be until next week when I get it back.
Please look at the power curve of both and you'll see that Turbo will have more power under the curve
Edit:
Edit:
Actually, I do believe this...I posted it. You're assuming that I'll start a roll-on race from low rpm. With a manual and rpm-based boost, I can start the race at 5k if I wanted. I'm aware turbos make more torque down low and I know how to read a dyno. I made my post based on the original poster's assessment of a 4 psi TT setup vs a 9 psi Vortech. I mean, that is the topic of discussion. I was just agreeing with the OP. Do I need to repost his reply? Did you accidently make a post to the wrong thread?
Vortech was at 7.X lbs, Greddy at 4psi until 5200, then drops down to 3.5. This was the first pull once it was tuned for wastegate pressure before the boost was turned up. It was also about 9X degrees and extremely humid.
The butt dyno does not lie. Down low, the TT's are no doubt faster than the SC felt, but up top the SC def has the edge.
None of this really matters in the long run. I just wanted to show the diff between the two setups via a plot. Even at 4 psi, the TT is making very good power compared to the 3.12 Vortech I had.
yeah, text is a bitch. People end up sounding harsher than they normally do. I don't always catch myself
look forward to the results man
I love these gadgets...lol
