In tank fuel pump install
Old Aug 12, 2007 | 04:17 PM
waijai's Avatar
i.love.gold
How long did it take you guys? I will be doing it this coming week probably...walbro 255. Should I make sure to have a close to empty tank?
Old Aug 12, 2007 | 06:49 PM
superchargedg's Avatar
It should take about 1 hour,make sure you get a new oring seal as the seal will expand quite a bit if it touch,s gas,which it will.It would be wise to have a dremel tool as you have to do some modifications to the fuel pump basket to make it fit.
Old Aug 12, 2007 | 10:47 PM
FastDontLie's Avatar
...we dont need roads...
^^+1
Anything under half a tank will be good, also a bucket to put the unit in so you dont leak gas everywhere. Also I think you need to make the small hole on the sending unit a little bigger (to a 7/64) with a drill. Good luck!!
Old Aug 13, 2007 | 09:07 PM
ttrank's Avatar
Grocery getter
I have had mine out a few times. It is not hard to just change the pump. 1-1.5 hours is plenty and you can do it with any amount of fuel but it helps a lot to have 1/2 or less.
Old Aug 14, 2007 | 12:26 PM
Triple8Sol's Avatar
Took around 1 hr. including time to modify the assembly per TN instructions.
Old Aug 18, 2007 | 12:57 AM
wayneside's Avatar
bring it to the shop...less than 15 minutes.
Old Aug 18, 2007 | 02:16 AM
waijai's Avatar
i.love.gold
got it in...thanks guys!
jsimonk
Dec 22, 2023 03:49 PM
usingthejohn
Media Share G35 Sedan V35
Sep 17, 2015 11:37 AM
Jroc2017
Aug 16, 2015 07:16 PM
