GT Motorsports: APSTT G35, GTM Longblock, F-Con Vpro, Paranormal Welcome Home!
Well we hope Paranormal enjoys his car now after his service in Iraq, he is definitely coming home to a true beast!
We are in the final tuning stages here is a prelimnary dynograph with a mix of 91/100 octane, fresh engine, at 14 psi.
"Delaware Dragster"
APS Twin Turbo Kit
APS 3.5in Down Pipes
GReddy EVO TT Exhaust
HKS F-Con VPro
HKS Knock AMP/AirFuel Monitor
HKS Navigator
HKS Fuel Press. Sesnor
HKS EGT Sensor
HKS Oil Temp Sensor
HKS Oil Press. Sensor
HKS Feedback Compensation Module
HKS EVC 6 Boost Controller
GTM Stage 0 Shortblock
GTM Stage 1 Heads
GTM Stage 2 Cams (272s)
GTM ECU Flash
CJM Stage 1 Fuel Return System
Power Enterprise 800cc Injectors
ATS Triple Disc Carbon Clutch
We had to take the car off the dyno because the boost is not very consistent in the higher rpms. The car came with these Forge actuators already on it. It is doing good around 1 bar boost, after that it tapers down to 13psi by redline. You can see this reflect in the preliminary graph below.
Sam
GT Motorsports
"Delaware Dragster"
APS Twin Turbo Kit
HKS F-Con VPro
HKS Navigator
HKS EGT Sensor
HKS Oil Temp Sensor
GTM Stage 1 Heads
GTM ECU Flash
Prelimnary Tune, 91/100 octane Mix, 14.7PSI:
Sam
GT Motorsports
Saw the car @ GTM while Sam was working on it.
Paranormal is going to love his G35 TT beast
Btw, you guys should check out the GTM's fan shroud upgrade product
Congrats Paranormal, I see my car in the background just waiting to leave also....damn turbo rebuild
Any ideas what the car will produce on crappy 91 octane only...trying to get ideas of what a normal daily driver would produce.
