fuel management system for Vortech S/C
Old Sep 29, 2007 | 05:25 PM
jonathine7486's Avatar
Im getting ready to install a Vortech S/C system on my 2003 Coupe. wanting to know what is the best management system out for my car not planning on running the Fmu that comes with the system wanting to upgrade the fuel management system for the best bang for the buck and easy to tune and able to get the most power out of
Old Sep 29, 2007 | 10:23 PM
Triji's Avatar
Walbro 255 in tank pump / 440 injectors / Utec..... done.
Old Sep 29, 2007 | 10:54 PM
pabg35's Avatar
Simple Ax6 G
agree with the fuel pump and utec, but 550 injectors if you are planning on future mods.
Old Sep 29, 2007 | 11:41 PM
Triji's Avatar
True that ^^^
I have 650's (for that just in case day)
I was thinking 440's if he was staying stock Vortech / 3.12... anything more than the 3.12 and you would need larger injectors.
Old Sep 30, 2007 | 10:20 AM
i want to run the 8 pound pully's
Old Sep 30, 2007 | 10:34 AM
pabg35's Avatar
Simple Ax6 G
most people get 7-8 lbs on the 3.33 pulley and 8-9 lbs on the 3.12 pulley
which pulley are you going to run and what is your whp goal?
Old Sep 30, 2007 | 11:03 AM
my goal is about 400 hp.
Old Sep 30, 2007 | 11:15 AM
what fuel management system should i run im looking at the aem and the utech and the greedy systems is there something else i should look at besides one of those system.i dont know if i want to go piggy back system
Old Sep 30, 2007 | 11:16 AM
pabg35's Avatar
Simple Ax6 G
depending on what you have installed right now on your G.
3.12 pulley
550 injectors
fuel return system
walbro fuel pump
UTEC or e-manange ultimate
hope you have tp or hfc, catback system, headers for your breathing mods
intake plenum spacer or upgraded intake
wideband for a/f ratio (AEM or Innovate)
depending on what dyno your tuner uses, temp, humidity that day. you will probably get around 360-380 whp
Old Sep 30, 2007 | 02:35 PM
dose anyone know if AEM offers the full stand alone engine management system for the G35. and how good is that system compared to others on the market
Old Sep 30, 2007 | 03:00 PM
Hexxum001's Avatar
I'm running the HKS FCon IS piggyback and would definitely recommend it. The only problem is that only an authorized HKS vendor can sell these and tune them. Aside from that, I would go with the UTEC.
Old Sep 30, 2007 | 04:02 PM
Deathmage's Avatar
your UTEC will kick in, yo (with some bigger injectors)
Old Oct 1, 2007 | 12:53 PM
G35Asian's Avatar
If you are looking to go with the Vortech Tuner Kit (no engine management or fuel options), definitely consider what Triji and pabg35 had suggested. As for injector size, it will depend on what you are looking to spend as well as any prediction for future mods. If you are not going with a return system then 550's or 650's with the stock setup and a walbro 255lph pump will do (this is what I am using). If you decide to get a return fuel system, 440's will work just fine.
Make sure to get the necessary breathing mods (i.e. exhaust, plenum or spacer, etc.) and a good tune. 400rwhp will be a stretch but you can make it with some race gas or meth. Good luck!
Old Oct 2, 2007 | 11:11 PM
I think i am going to run the Greedy E manage ultimate with the plug and play harness. with 550cc injectors
Old Oct 3, 2007 | 10:49 PM
booger's Avatar
You would have less trouble having the ECU flashed for bigger injectors and run the SS box . E-Manage sucks !!!!
Get the Utec...acts like a standalone for fuel and timing and costs about the same .
