maf question
Old Oct 2, 2007 | 08:47 PM
TTg35sedan's Avatar
maf question
I am new to this sight but here goes. I have a 2006 G35 sedan. the motor is built and twin turbo, the problem is i cant boost over 8 to 10 psi because the voltage on the maf is going over 5v and puts the car in limp mode, anyone have any ideas
Old Oct 2, 2007 | 09:41 PM
Andy2434's Avatar
Welcome to the 'Driver boards,TTg35sedan. Hopefully, your question will be better served in this section.
Old Oct 3, 2007 | 12:23 AM
2slo2bfurious's Avatar
What kind of engine manage. are you running?
Old Oct 6, 2007 | 10:21 AM
Q45tech's Avatar
Unfortunately most MAF are designed for a max of 255 grams per second.
You might get a specialty MAF built for higher flows? Even the 5.6L MAF will max out at 380 HP.
These might be helpful:
http://www.ecutek.com/tuning/induction/
http://www.jimwolftechnology.com/wol...WIRINGINST.PDF
Old Oct 6, 2007 | 12:34 PM
waijai's Avatar
i.love.gold
I have the TurboXS UTEC which is tuned using MAP sensor and speed density fueling.
Old Oct 8, 2007 | 12:25 PM
Matt at PF's Avatar
you are probably running an emanage, you need to clamp the maf voltage at under 4.7 volts on there.
good luck with it, if you are in the Florida area, bring it to us to take care of for you...
Machine Head
19 Inch
Mar 16, 2016 08:55 PM
SilverG123
Engine - Electrical
Sep 4, 2015 01:12 PM
UT G35
Sep 3, 2015 03:58 PM
INVADER_6MT
Sep 1, 2015 10:19 PM
G35Sask
Intake & Exhaust
16
Aug 5, 2015 10:17 PM
