need engine harness badly
Old Nov 30, 2007 | 07:41 PM
alan21's Avatar
i need an 03 to 04 g35 coupe 6mt engine harness anyone have one or know where i can get one?
Old Nov 30, 2007 | 10:50 PM
Gspott's Avatar
Why is it that you need one..?? Is it the main harness..?? I think i need one also. The one that the O2 sensors connect to the exhaust manifold & cats.They were damaged when I ran over some tire tread & as it was rolling underneath my G, it damaged one of the connectors that goes to the passenger side "after cat" O2 sensor. The plug from the sensor that connects to the wiring harness. that connector from the harness got demolished, the only thing left is the actual pins that connect to the sensor. Luckily, the 2 sides still connect but don't want to keep it like that. Deffinitely could be problematic in the future. Water intrusion etc. I'm not sure if a new plug could be spliced in or what..?? Going to West Covina Nissan in morning so it can be checked out & reset my "check engine" light that lit up after the sensor was disconnected. Anyone of you guys have some suggestions..??
Old Dec 1, 2007 | 12:46 AM
alan21's Avatar
i got a built motor and engine harness is damaged and i dont want to reuse it
Old Dec 1, 2007 | 12:06 PM
alan21's Avatar
anyone please i want to start my car up
Old Dec 1, 2007 | 07:54 PM
accordfreak's Avatar
I have an engine harness from a 2003 6mt 350z. UNCUT. It doesn't have the injector extension harness though but you can disconnect yours and plug it into this one.
$240 shipped.
Old Dec 1, 2007 | 08:05 PM
alan21's Avatar
let me look at my harness thats damaged and compare it to this one. Yours looks like it has one additional plug after the gromet where it enters the car...
Old Dec 1, 2007 | 08:06 PM
let me know if you need any close up pictures..
Old Dec 1, 2007 | 08:39 PM
alan21's Avatar
its different it has one extra connector
Old Dec 2, 2007 | 09:30 AM
alan21's Avatar
bump i really appreciate all the pms but i dont think the one off a 6mt 350z will work bc of the extra connector can anyone tell me for sure?
Old Dec 2, 2007 | 04:00 PM
alan21's Avatar
bump need a harness asap!!!!!!!!!!!!!!!!!!!!!!!!!!!!
Old Dec 2, 2007 | 06:11 PM
Audible Mayhem's Avatar
the G35 and Z harnesses are different.
if oyu need one
call jim at www.turbo-toys.com , tell him i sent ya!!
Old Dec 3, 2007 | 12:37 AM
2slo2bfurious's Avatar
I have one for an extra 2003 harness too, but the o2 sensor plugs are different from my 2004's harness. So if you have an early 2004 maybe its the same... pm me I'll give it to you for cheap if its the one you need.
Old Dec 3, 2007 | 07:30 AM
the plugs are different on the later 2004s , they changed over to airflow meters in the exhaust manifolds instead of o2 sensors.
Hasanbaloch
Feb 29, 2024 08:45 PM
03sedang35
Aug 29, 2015 07:56 PM
StephonW
Aug 29, 2015 01:24 AM
newg37
Jul 26, 2015 09:32 AM
Jadenkid22
Jul 14, 2015 12:33 AM
