Gas Guage Gone Crazy
Old Dec 6, 2007 | 12:05 AM
KiNG KoNG1's Avatar
After I Installed My Fuel Pump.. The Gas Guage Is All Over The Places And Wen I Fill The Car Up It Stops After A Quater Of The Way Up.. Anyone Else Has This Problem?? How would i know if i had a gas leak or a gas flow problem?? im running nitrous soo this could be devastating.. I already had a nitrous backfire soo im worried
Old Dec 6, 2007 | 12:14 AM
waijai's Avatar
i.love.gold
Take out the fuel pump assembly and make sure the gas level sensor is place in correctly and not tangled by any wires.
Old Dec 6, 2007 | 12:50 AM
KiNG KoNG1's Avatar
could the gas guage sensor have causes my nitrous backfire how do i know its not a fuel flow problem??
Old Dec 6, 2007 | 06:19 AM
Audible Mayhem's Avatar
the gas gauge is cause you messed up the sending unit. you can buy one at nissan for about 100 dollars. be CAREful when you put it back in. it is very easy to break.
the nitrous backfire is probably due to one of two things. you either dont have a TPS switch working right or you have a slow nitrous leak through the solenoid.
you need to be careful with nitrous as well, i would hate to see you posting up how it blew up your motor due to incorrect way of installing it...
Old Dec 6, 2007 | 11:23 AM
KiNG KoNG1's Avatar
i have a WOT switch and thats about it.. how would i know if i had a slow leak through a solenoid??and would the sending unit have anything to do with the backfire??
Old Dec 6, 2007 | 08:23 PM
the reason you blow your intake off is having nitrous in your intake with the throttle plate shut. i would have a professional shop check out the install.
you should not have that problem...
good luck!!
Old Dec 7, 2007 | 12:29 AM
KiNG KoNG1's Avatar
what could cause that?? sorry im asking alot of questions but when i go to the shop i want to being informed so they just dont tell me the car is fine and send me on my way.. so u think the cause of it was a bad install?? and could i have damaged something besides the intake??
Old Dec 7, 2007 | 02:06 AM
KiNG KoNG1's Avatar
yea i think im going to need to do that.. is the sensor something that needs to be fixed immediately?? does it do anything besides measure the gas levels?? and i tried to google nitrous backfire and it said something to do with lean or rich conditions and pooling.. could someone simplify a nitrous backfire and really let me know what im dealing with??
Old Dec 7, 2007 | 08:06 AM
i would fix the sensor pretty fast, its a 100 dollars. i know a guy who had one that was messed up and thought he had gas and got stranded...
also, take it to another shop to check out the nitrous, it shouldnt be ever blowing your intake off...
Old Dec 8, 2007 | 01:15 AM
KiNG KoNG1's Avatar
i went to a reputable shop and i was told too get rid of the nitrous and get a single turbo because nitrous in the end leads to bad things..i think thats whats about to happen without getting the single turbo...
Old Dec 8, 2007 | 01:21 AM
KiNG KoNG1's Avatar
how much would it cost do u think to have a reputable shop look over it and lets say "tighten" or reinstall somethings??
RemmyZero
V36 DIY
Apr 23, 2018 11:13 AM
Video Share
Jan 31, 2017 04:00 PM
g.spot
May 9, 2016 10:54 PM
prinny
Nov 22, 2015 11:07 PM
Hogbone
Sep 28, 2015 06:44 PM
