Variable geometry turbos
Old Dec 17, 2007 | 08:03 PM
aero's Avatar
I've been hearing about this technology for months now, but I never found a good writeup until now, thought I'd share for anyone who's interested. The example given is the 997 911 turbo, apparently the moving vanes allow it to hit full boost at 1500 RPM!
Mentions that the technology was stolen from the aerospace industry, probably from turbofan or turbojet engines.
Hurry up Greddy!!!
http://paultan.org/archives/2006/08/...geometry-work/
Old Dec 17, 2007 | 08:13 PM
Jeff92se's Avatar
Red Card Crew
I believe the Acura RDX also uses this type of tech
Old Dec 18, 2007 | 09:42 AM
aero's Avatar
Hadn't heard about the acura version, found the attached features. Looks like they use one big valve to control total exhaust flow. Man I hope aftermarket companies jump on this bandwagon.
Old Dec 18, 2007 | 09:53 AM
617G's Avatar
CFW (Carbon Fiber Whore)
the picture you posted IS the acura version
Old Dec 18, 2007 | 10:36 AM
roneski's Avatar
Devil's Advocate
The "Acura version" is not variable vane.
Old Dec 18, 2007 | 10:43 AM
aero's Avatar
Hadn't heard about the acura version [BEFORE], found the attached features [AFTER YOU MENTIONED IT]
Could I possibly be that stupid!? Jesus guys.
Old Dec 18, 2007 | 10:48 AM
617G's Avatar
no, but they both do the same thing...
Variable Vane:
"In this cut-through diagram, you can see the direction of exhaust flow when the variable vanes are in an almost closed angle. The narrow passage of which the exhaust gas has to flow through accelerates the exhaust gas towards the turbine blades, making them spin faster. "
The Acura version uses a valve to narrow the passage of the exhaust making the exhaust flow faster. Not exactly the same, but the principle is the same.
Old Dec 18, 2007 | 10:49 AM
617G's Avatar
you'd be surprised
Old Dec 18, 2007 | 12:18 PM
aero's Avatar
you'd be surprised
Funny, after I posted I was thinking the same thing! There are actually people that stupid, I live around thousands of them!
Old Dec 18, 2007 | 12:27 PM
Hexxum001's Avatar
I'm suprised that none of the aftermarket companies that make turbo kits thought of this before. It makes a lot of sense for minimizing lag.
Old Dec 18, 2007 | 12:42 PM
aero's Avatar
From what I've read, sounds like the problem is the actuators. I guess the small moving parts can't handle the heat. That's supposedly what they borrowed from aerospace, some exotic material that can take the heat and still move the vanes precisely.
Old Dec 18, 2007 | 12:43 PM
pjames's Avatar
it looks rather expensive...
Old Dec 18, 2007 | 12:47 PM
Jeff92se's Avatar
Red Card Crew
I think GM dabbled in this tech also. I think aero is right. All those little parts had a hard time dealing with the heat and probably the exhaust junk
Old Dec 18, 2007 | 01:08 PM
Hexxum001's Avatar
Good point. I guess they would have to use a different kind of material that can handle the heat. That might drive up the price a bit to make it work. It's a great idea though if they can make it work without drastically driving up the price of the kit.
Old Dec 18, 2007 | 01:14 PM
Jeff92se's Avatar
Red Card Crew
Yes I'm using Stupid Street mag as a source but it's a decent link. haha
http://www.superstreetonline.com/tec.../pictures.html
