Wideband
Old Feb 6, 2008 | 03:18 PM
CHudson Coupe's Avatar
Wideband
Does anyone know of a wideband A/F gauge for under $200?
Also, if i turn the boost down and want to get good milage for a long trip, I lean the mixture a little, what is typically a safe high limit of A/F, and also for going fast and I richen the mixture, what is typically a safe low limit of A/F?
Old Feb 6, 2008 | 04:17 PM
sliderg35's Avatar
Perfect A/F under no load is 14.7. That is the number that represents all of the fuel being burned completely. Going fast is not the problem, higher load is. At max load, you should be down to around 12. Some people go as low as 11.4. With a proper tune, all of this is handled for you. There should be no need to change the mixture to go on the highway. If you don't boost, your A/F will stay in the high MPH area.
Old Feb 6, 2008 | 05:58 PM
FI'ed G's Avatar
/\+1.. I like mine around 11.3-11.5 at full boost and in the winter season. In the summer days then I have mine to compensate around 11.0 -11.2 especially when it is hot. A/F and timing is also depend on what gas you are using so Cali guys may run a little conservative than NE guys were 93 octane is widely available.
Old Feb 6, 2008 | 06:02 PM
ttrank's Avatar
Grocery getter
I have my zeitronix wideband w/bosch, boost and egt sensors I will be selling soon. Everything for ~$400 including the mount for your defrost vent just to the left of your dash.
9tray turbo
Sep 29, 2015 10:22 PM
usingthejohn
Media Share G35 Sedan V35
Sep 17, 2015 11:37 AM
G35pm
Archived Sales
Oct 24, 2006 06:58 PM
