FI-Compatible NA Mods
Old Mar 20, 2004 | 01:41 AM
shivak's Avatar
I'm eventually going to get a Twin Turbo, but in the meantime, I'd like to load up on some NA mods. I've done some research on this forum and on my350z, and I'm trying to assemble a list of what NA mods one could keep with an FI car. Here is what I've come up with so far:
Compatible
-Exhaust
-Camshafts
-High Flow Cats
-ECU (will have to be reflashed, but still..)
-Torque Converter (5AT)
Incompatible:
-Headers
-Intake/Popcharger/Z Tube
Unsure
-Plenum
-Flywheel
-Pulleys
There are probably errors and/or omissions in the list. Would anyone more knowledgable care to revise it?
Old Mar 20, 2004 | 03:18 AM
dollar99's Avatar
Re: FI-Compatible NA Mods
your tranny will not shift at WOT with FI. Might think about getting a new tranny. Also, auto tranny's don't use flywheels.lol.
Also, the cost of labor involved in installing cams are pretty high, why not get some lower compression pistons, titanium retainers and valves while you're in that territory? It will probably cost $1500+ just in labor to install those internals. Another $2000+ for install/tuning your TT's. I hope you're rich.
_________________________________
430+ Horsepower at the crank.
Old Mar 20, 2004 | 09:38 AM
Carlos3186's Avatar
no need for a new tranny, but u are right it wont [censored] at WOT. You will need to get the techno square ECU to raise the rev limiter and that will give the auto enough time to make a clean [censored]. The car will shift in manual mode though.
Good luck
<a href="mailto:Carlos3186@hotmail....otmail.com</a>
Old Mar 20, 2004 | 03:26 PM
fluffydot's Avatar
hey dollar99,
I've been thinking about the same thing... trying to get some NA mods that are compatible with FI since I am not sure which way I will go...
You have RT cats right? what is the pipe diameter?
what kind of exhaust do you have?
think those cats + fujitsubo would be alright for a TT setup?
Old Mar 20, 2004 | 09:20 PM
tig488's Avatar
carlos...are you mispelling shift or what? ive never seen you say so much obscene language. haha
BS/Graph 6MT Cp
19" GunM TE37 275/30 MPSports
kg/mm,cambers,cuscosways,injen int/exh,Alpine/JL/Stinger,topsecret
Vortech
Old Mar 21, 2004 | 03:53 AM
GurgenPB's Avatar
Not sure about cams on turbo. If you do, you cannot go with the high duration ones. You are pretty much restricted to the Nismo cams (256 degrees i believe). The tomei 26x degree cams a big no no. You can't have the overlap on FI with cams. They pretty much have to be higher lift, and no change in duration (ideally). That's how I understand it. I would personally not spend money on cams, that's not going to be a limiting factor by any meaningful means. Also, if you do cams, the rest of the engine is a must, as the pressure on the rods will be VERY high. I would do cams IF I had the money AND I was doing the rest of the engine!! Then you can REALLY throw down some power.
Gurgen
Old Mar 21, 2004 | 07:11 PM
Carlos3186's Avatar
haha yeah tig488 i was trying to say shift and not [censored]... damn typos. haha thats funny
Charchar66
Dec 19, 2019 01:17 PM
Video Share
Jan 31, 2017 04:00 PM
g.spot
May 9, 2016 10:54 PM
prinny
Nov 22, 2015 11:07 PM
RWDguy4238
Sep 30, 2015 12:13 AM
