non-revup compared to revup engines going FI
Old Mar 18, 2008 | 09:47 PM
nyqueenz's Avatar
Dose it really make a difference between the 03-04 VQ35 and the 05 and up VQ35 power wise when going FI.. If both had the same exact tune done? I know the 05 and up revup have more aggressive cams, but do they both see the same power band when in boost?
Old Mar 18, 2008 | 10:42 PM
FI'ed G's Avatar
not much but AT and 6MT there is definitely a difference. Revup may give a little better number but not that much. I hit 392TQ/373whp at around 8psi with my Revup and other STS non-revup 6mt's are around 360whp-370whp with the same boost. Like I said, the difference is minimal, but my boost also drop after 5700rpm to only 7psi so who knows...
Here look at my dyno you can see my power drop at 6000rpm, I wish I can make more power all the way to redline. Also my A/F dip to the 10's at 6000rpm. I also have Water/Meth kit so not sure if that added power but I didn't touch my Timing Map and didn't lean out my A/F so the meth shouldn't have done anything drastic. I know to many variable so comparisson should not be made...lol
Old Mar 18, 2008 | 11:39 PM
sliderg35's Avatar
Your A/F dip to 10 at 6000 explains your loss of power.
Old Mar 19, 2008 | 10:29 AM
FI'ed G's Avatar
/\ lol there are to many variables.. 1. I Have a 4.3psi wastegate spring so at 8-9 psi I'm already maxing it limits 2. If you look at the MREV+ dyno, the power is shifted to the midrange and sacrifice top end power on Revup 3. Utec BCS is not really as good as an EBC... there are more I can think off but they are minor... Other STS who uses an EBC all hold boost until redline.
Freeman186
Sep 6, 2023 10:07 AM
sales@czp
Suspension-Vendor
26
Nov 6, 2017 03:04 PM
Joe Gargano
Sep 18, 2015 11:17 AM
AuAltima3.5
Sep 13, 2015 10:53 AM
