Max psi on a stock 2003 g35 engine
Old Mar 25, 2008 | 12:44 AM
  #31
nyARISTO's Avatar
Wow with that motor! hmmm what about tranny? whats max power on that ? either man. or auto
Old Mar 25, 2008 | 04:01 AM
  #32
XKR's Avatar
XKR
Originally Posted by citymunky
All I did is provide you with my info, to show it's not impossible like you making it seen. Now let me clear some things up: 150+ dyno pulls were not all at 18 PSI. From the base line of 364.4 WHP (6 PSI) to 423.1 WHP (9 PSI) there were 50+ pulls. From 423.1 WHP to 490.4 WHP (12 PSI) was about 30 more pulls. From 490.4 WHP to 541.4 WHP (14.1 PSI) there were 40+ pulls. And finally from 541.4 WHP to 563.7 WHP (18.9 PSI) there were 30 or more pulls.
Well .... my original point was 150 pulls at 18 psi' s on stock motor aint happening. Your response does not show me that. Thats like saying I ran 100 miles in an hour...but then coming back later and saying ...I drove 95 of those miles....but I still went 100 miles in an hour.
Even with the numbers you posted above...the motor would not last on the street.
Old Mar 25, 2008 | 06:10 PM
  #33
citymunky's Avatar
Duh.
I was arguing my point that the Nowell's stock motor did product 563.7 WHP @ 18PSI with 150 dyno's pulls in the engine's liftetime. And you were arguing your point that their no way the stock block did all it's dyno pulls @ 18 PSI. Which in your case I was wrong.
I never said at those HP levels that a engine would last long. Nor do I think any real tuner would you drive out of their shop with a tuned G/Z boosted to 18 PSI on a stock block. Nowell's engine only lasted 4 days in total and like 16 minutes on street. But for those 16 minutes the VQ held on . I'm 99.9% sure if they would have pushed it to 19 PSI, the engine would have blow on the dyno.
All was doing was answering the OP question of :
Originally Posted by mightyb28
How much boost will a stock g35 engine take and without any other mods (heads, exhaust) could you expect to make before the pistons shot through the hood??
I reply with the video (To show the MAX PSI), and said below it, that 10 PSI would be safer.
Old Mar 25, 2008 | 09:49 PM
  #34
XKR's Avatar
XKR
Duh.
OK....I am with you
TWASkyliner
Feb 8, 2020 08:00 PM
Augy
Steering & Suspension
Sep 8, 2015 12:53 AM
Rehman2009
Jul 27, 2015 03:23 AM
Chattzx
Jul 17, 2015 11:23 AM
