ISSUE WITH HFC on my ATI PROCHARGED G35..Should I go TP's
Old Mar 25, 2008 | 04:32 PM
g35man04's Avatar
CLUB MODERATOR
Originally Posted by usmcmark
yep, you should try runnin' ur stock exhaust manifolds... if ya still have 'em. you might even gain so HP, i've heard that SC's need a lil' back pressure to achieve optimal performance. lemme know what happens... thanks
yeah I will think about it...that is a hell of alot of money to put stock ones back on...then again the sound will probably better as well.
Old Mar 25, 2008 | 06:21 PM
G37Rider92649's Avatar
G35MAN04 Do you have belt slippage problem with the 10psi pulley upgrade?
Old Mar 26, 2008 | 12:48 AM
Xblackg35X's Avatar
or a built engine?
Old Mar 26, 2008 | 12:49 AM
Xblackg35X's Avatar
or a built engine?
Old Mar 26, 2008 | 01:31 AM
g35man04's Avatar
CLUB MODERATOR
no belt slippage issues since it comes with 2 pullies for the upgrade. I had the issue with eating the belts....I have already replace the belts on once.
Old Mar 26, 2008 | 01:37 AM
Skaterbasist's Avatar
Retired SuperMod
Stick with the HFC in my opinion, I went test pipe and i raaaaaasp sooo much!!! Nasty annoying rasp, I hate it, and I really hate forcing my self to like it cause I own one, I have the Kinetix HFC right now with my F.I exhaust with a procharger set up, no problems. I was thinking of switching to to FI HFC if anything ever happens, as for if you really want test pipes, atleast get resonated, cause I got non-resonated, sh*t was annoying ....and all this of course is my opinion..hope you solve your minor problems buddy..
You had rasp with F.I Resonated test pipes AND the F.I exhaust combo?
I have the same setup, and have almost no rasp @ WOT. And no rasp during daily driving.
(Even though you are supercharged).
Old Mar 26, 2008 | 04:14 AM
^^ Nooooo if I had the FI Test Pipes I wouldn't expect rasp, I hed some Titek Test Pipes Much cheaper then the FI haha
Old Mar 26, 2008 | 04:04 PM
FastDontLie's Avatar
...we dont need roads...
I just installed some top speed resonated test pipes. So far now rasp..... I am running TP's & HKS tru dual. I love the sound
Old Mar 26, 2008 | 09:59 PM
Xblackg35X's Avatar
^same here resonated topspeed test pipes. I LOVE THEM. no rasp
Old Mar 27, 2008 | 01:38 PM
waijai's Avatar
i.love.gold
Thumbs up to the guys at Top Speed!
Old Mar 27, 2008 | 01:52 PM
g35man04's Avatar
CLUB MODERATOR
I am wondering though if having Topspeed headers is going to result in Rasp...I had test pipes before. What I may do is switch back to Stock Manifolds and put on Topspeed Test Pipes...maybe my exhaust note will be alittle bit deeper as well.
Old Mar 27, 2008 | 01:53 PM
SDGeneralCounsel's Avatar
Prochargers should never have belt slippage problems because the belt has teeth. Only the vortech and like kits have slippage problems. Prochargers have problems with grinding teeth of the belt (I thought).
Old Mar 27, 2008 | 02:38 PM
g35man04's Avatar
CLUB MODERATOR
correct the pulleys teeth start getting sharper which is the cause to why the belts break....or teeth gripped stripped all the way off the belt.
Old Mar 27, 2008 | 06:07 PM
zazaracing's Avatar
Team Transport Member
test pipes FTW
Old Mar 27, 2008 | 07:18 PM
  #30
BeerViper's Avatar
I've been running Kinetix HFC's for over 20k boosted miles and no issues here. I have also heard that running headers will do that to the cats but I really don't know why...
