Supercharger questions/concerns (all F/I welcome :D)
Old Apr 6, 2008 | 08:06 PM
imalazeeass's Avatar
^good call
Old Apr 7, 2008 | 10:21 AM
anDross's Avatar
Thanks once again guys. Hey sportcoupe what kit are you using?
Old Apr 7, 2008 | 01:41 PM
BeerViper's Avatar
1) At ~14k miles installed Vortech full kit (w/3.33 stock pulley, Split Second piggyback, Vortech aux fuel regulator)
2) 33,000 boosted miles and going
3) I get anywhere between 280 - 320 mpt. I just got new tires and an alignment so that might even go up now.
4) Stock: block, injectors, fuel pump Upgrades: 1/2" MD Plenum spacer, Injen true dual exhaust, 2 x Kinetix high flow cats
That's basically it ... It had been my DD for about 6 months and essentially still is but I work from home now so don't drive as much.
This car has seen both the dragstrip and the track on several occasions. When taken to the track though I will always run about 1/2 tank of 106 Octane for safety.
Only problem I ever had was one of the two bearings inside the cog assembly went bad and was making a loud whining noise. I diagnosed and fixed it myself...
My suggestion is to start out finding a tuner that implicitly knows the Split Second software (for the full kit) or Utec software and push for a conservative tune (don't advance timing for a few extra hp). Get the A/F graphs through the RPM range. IMHO this is going to be the biggest factor in the longevity of your motor.
GL!
Old Apr 7, 2008 | 10:24 PM
Sbeck's Avatar
Originally Posted by G35Tuning
Go over to www.my350z.com
Search a thread titled "Vortech FAQ"
There you will find EVERY single detail about anything Vortech related...I dont have any experience with the kit...But from those I've talked to it seems that even someone with minimal experience with installs should be able to do things rather easily...Just go slow and be sure to read each direction twice...Find that thread over at 350z.com and I promise you'll feel much more comfortable...You and your father will have a good time doing it...I hope your not too young as thats a good amount of power to be pushing...Be easy with her, and enjoy...
Thanks so much man. I appreciate the fantastic response.
Old Apr 8, 2008 | 01:02 PM
anDross's Avatar
GL!
Thank you very much for your time and input.. Very much appreciated!
seagrasser
May 3, 2022 09:43 AM
Mad A
DFW Classifieds
Mar 28, 2016 11:25 PM
Mad A
Not G35 Related
Dec 8, 2015 01:45 PM
linedr89
Engine - Power Adders
Oct 4, 2015 07:29 PM
9tray turbo
Sep 29, 2015 10:22 PM
