which exhaust for vortech??
Old Apr 6, 2008 | 02:13 AM
cchaorule's Avatar
which exhaust would perform better with vortech.. i know both of these exhausts arent the best.. but.. outa these 2 which one is better.. the amuse R1 titanium or the HKS hi power Ti..??
Old Apr 6, 2008 | 02:15 AM
Skaterbasist's Avatar
Retired SuperMod
What's the diameter of the R1 Ti again?
Anything 2.5 inch would work well. The HKS is too small to make good power.
Old Apr 6, 2008 | 02:18 AM
cchaorule's Avatar
hmm im not sure.. but a true duel liek the hks would perform better than jus a catback right??.. the only reason i am considering these 2 exhausts is because its local..
Old Apr 6, 2008 | 02:54 AM
jonnylaw's Avatar
amuse is 3 inches for b pipe then goes into twin 50mm canisters in muffler section, and exits 4 inch tips. I plan on using it with a sc. hope that helps.
Old Apr 6, 2008 | 03:04 AM
Retired SuperMod
What do you mean "just a catback"? There are many other exhausts out there that would do the job better than HKS on a centrifugal/turbo'd G35.
I advise you to stick with a 2.5 inch exhaust. Anything bigger and you'll have too much flow for a Vortech. Anything smaller and you'll be choking up-top.
PS. HKS is a 2.25 inch exhaust; great for NA, not for FI.
Old Apr 6, 2008 | 03:36 AM
cchaorule's Avatar
thanks for the feedback skaterbasist... but my 2 options are the hks and the amuse r1 because they are local.. which one out of the two do you think is better for my vortech
Old Apr 7, 2008 | 05:35 PM
booger's Avatar
A [ no cat ] 2.25 true dual exhaust will flow plenty for the power the stock Vortech kit makes . And even should be good with the smaller 3.12 pulley on it . I have a Stillen exhaust [2.3x in. ] and it should be good to about 500hp . I am getting my car tuned right now and will be nmaking around 20psi of boost . I may have to go to a bigger exhaust soon
Old Apr 7, 2008 | 05:39 PM
BlueDevilBAMF's Avatar
If you had to pick between the two and are running low boost, HKS would be best
Old Apr 8, 2008 | 07:26 PM
SIN3's Avatar
fujitsu Y pipe
to 3 inch piping straight back no cat to hks single c/f TI muffler. ftw
Old Apr 8, 2008 | 08:27 PM
KapVu's Avatar
how is the FI exhaust for the vortech?
Old Apr 8, 2008 | 10:15 PM
SDGeneralCounsel's Avatar
Wrong. I just saw one a couple weeks ago that was making over 600 whp on race gas and it was running the HKS exhaust. Also, the HKS exhaust is about 2.5" (60mm = 2.362204724412").
Old May 4, 2008 | 04:58 PM
NDG35CHO's Avatar
I was planning on getting a 3" APS ehaust with a Vortech setup. So is this a bad idea?
Old May 4, 2008 | 05:13 PM
Canadian's Avatar
Canada, eh?
I'm running the HKS on 7psi and make 355whp, so it's not that bad. Plus it sounds amazing.
Old May 4, 2008 | 06:21 PM
mrimage's Avatar
i am running the greddy SP and making 373 WHP@ 9psi
Old May 4, 2008 | 08:26 PM
Hexxum001's Avatar
I'm running Fast Intentions Intimidator exhaust which is 2.5 inch piping and it works beautifully with the Vortech. I had HKS before this and I made more power and a lot more torque with the Fast Intentions exhaust. But if HKS and Amuse are your only choices, definitely go with HKS. I still love that exhaust and wish they made it with 2.5 inch piping.
