Need some help with tightening the belt on vortech
Old Apr 20, 2008 | 03:09 PM
TwilightBLUES's Avatar
man this thing is squealing like a pig after i installed it about 2 weeks ago...its time for it to be tighten... anyone have some advice or a DIY? i dont wants to f*ck it up and not be able to drive the car to the shop.
Old Apr 20, 2008 | 03:16 PM
express705's Avatar
is it the tensioner?
Old Apr 20, 2008 | 03:32 PM
it is the micro v serpetine belt...if thats the same
Old Apr 20, 2008 | 03:34 PM
i found a DIY im contemplating doing it. hopefully all goes well.
im tired of making an apointment to go to the shop just to tight the damn thing
express705's Avatar
pm me with your specs please, if you dont mind
your car, mods, AT or MT, dyno numbers.
Old Apr 20, 2008 | 03:41 PM
pm sent
Old Apr 20, 2008 | 03:53 PM
express705's Avatar
thanks
Old Apr 20, 2008 | 04:18 PM
booger's Avatar
find the tentioner pulley.....loosen the bolt for it [ 14mm socket ] Take the plastic pan off the bottom of the engine bay [10mm socket ] .....find the tentioner [ 12mm socket ] tighten it till the belt only has 1/2 inch play....test it at the longest span of belt . Tighten up the pulley bolt......bingo !!!!! your done
Old Apr 20, 2008 | 05:30 PM
sounds very simple booger! ima try it right after the game..... go lakers!
Old Apr 20, 2008 | 07:57 PM
worked like a charm... thanks fellas
Old Apr 21, 2008 | 03:17 PM
kzanard's Avatar
The only pain in the whole process is removing the plastic tray to get at the bottom bolt. You can just cut an opening in the plastic (or remove it altogether) to make adjusting the belt even easier.
seagrasser
May 3, 2022 09:43 AM
Mad A
Not G35 Related
Dec 8, 2015 01:45 PM
reaper76
Sep 20, 2015 11:59 AM
