Too many miles to go boost?
Old Apr 23, 2008 | 10:46 PM
DG35Cpe's Avatar
I have 76,000 miles on my 04 auto coupe. Is it too late now to think about getting supercharged? Just curious if it is even worth it and if i should expect more problems with this many miles. The car has been maintained perfectly with oil changes and belts and everything else. Thanks
Old Apr 23, 2008 | 10:51 PM
Nismo G's Avatar
Never to late to go boost. Your engine is going to be good literally ever. Your transmission is the only thing i would worry about mine is still strong after 120K.
-Sean
Old Apr 23, 2008 | 11:07 PM
Hexxum001's Avatar
As long as your engine is in good shape, why not. Go for it.
Old Apr 24, 2008 | 09:41 AM
FI'ed G's Avatar
Get a compression and leak down test and if you pass with flying colors then you are golden. Can't really answer this question coz it really depends on how you maintained your car and how was it driven during those 76,000 miles.
Old Apr 24, 2008 | 09:44 AM
GreenGoblin's Avatar
The goblin resurrection
^+1
Old Apr 24, 2008 | 10:06 AM
DG35Cpe's Avatar
Where can I get a compression and leak down test done at? I am in south fl, also anyone know a good shop in my area that is proven to do good work on G's? Thanks
Old Apr 24, 2008 | 01:36 PM
Drewer's Avatar
You can do a compression check yourself if you can change your spark plugs.
If you have an air compressor, you can also easily do a leak down check yourself.
I'm going to do a leakdown before I throw my vortech on and I'm at 112k miles, since I have a decent pressure regulated air compressor. Should happen in the next few months.
Old Apr 24, 2008 | 01:39 PM
iknowitsfast's Avatar
im at 66k miles and thats exactly what i need to do. The compression and leakdown tests on my car before I boost
Old Apr 24, 2008 | 01:44 PM
Drewer's Avatar
You only need to do one or the other. A compression test is easier, but not nearly as telling as a leakdown test.
Old Apr 24, 2008 | 01:47 PM
^^ahhhh cool man, thanx!
Old Apr 24, 2008 | 02:58 PM
98intrigue's Avatar
86k miles on my 2004 with 22k miles being booster...going well so far. I say it's never too late.
Old Apr 24, 2008 | 03:16 PM
silver g's Avatar
Nah...I'm going boost this summer and I have 91K on my car. But I am having the engine completely rebuilt and all new heavy duty internals.
Old Jun 8, 2008 | 11:38 AM
DG35Cpe's Avatar
anyone have the compression specs the engine should be at?
Old Jun 9, 2008 | 01:35 AM
Drewer's Avatar
10.3:1 But this is only be for the 280/270 03-05 engines that aren't revups.
Old Jun 9, 2008 | 08:59 PM
ttrank's Avatar
Grocery getter
I had just over 70k on my car when I built the motor and it was running great. I just wanted more power. Of the 70k over half of it was boosted either Stillen stage 2/3/4 or Greddy at 8-10lbs.
jsimonk
Dec 22, 2023 03:49 PM
djreinx
Engine - Electrical
Dec 10, 2015 01:48 AM
usingthejohn
Media Share G35 Sedan V35
Sep 17, 2015 11:37 AM
linedr89
Aug 17, 2015 05:11 PM
Herbbie Hablib
Forced Induction
Aug 11, 2015 06:22 PM
