Vortech guys: please help...=(
Old Apr 28, 2008 | 11:11 PM
express705's Avatar
alright so after i installed my kit last week, ive run into a few problems.
i made a mistake with the fenderwalls and they got shredded while driving. so i cut them the best i could, and now they are starting to destroy my tires. if it gets worse, it could be a serious safety issue. what can i do about that?
my catch can isnt "catching" any oil. should i try the old steel wool trick?
my bypass valve is getting stuck, randomly. what i mean is this. while driving, it sounds like a diesel, or someone trying to whistle but cant and its very loud and annoying. this started today, and its happened twice. it does go away, and i think the valve is getting stuck. should i take it off and clean it and take it all apart and put it back together? the first time it happened i noticed a small amount of oil. this cant be good. are my seals bad? its very expencive to get those repaired.
also, i have a burning smell after im driving. it smells like hot, and when im stopped at a light after long driving, i see intermittent white smoke. when i open the hood its coming from the back, by the firewall. its not ALOT of smoke, but noticeable by me. its weird, but it could be a few things:
1- when doing injectors, i forgot to clamp a coolant hose and the back insulation by the firewall got soaked. it could be burning off still.
2- oil is getting into the cats and is being burned.
3- oil is burning from somewhere else?
4- ?????
5- exhaust leak
what do i do about all this? its really wearing me out and i shouldnt be having these stupid problems
thanks.
Old Apr 28, 2008 | 11:21 PM
imalazeeass's Avatar
edit** see that you installed yourself..
have u ever considered bringing it to a shop for a little piece of mind?
Old Apr 28, 2008 | 11:25 PM
G37Rider92649's Avatar
The white smoke may due to you running to rich possibly because of your injectors, did you get it tuned? If you didn't you definitely got to have it tune, thats all i know for the injectors part, unless you made a mistake while installing it.
Oil in anything may possibly mean there is a leak somewhere, if i were you i would take it to a shop and have it checked out, I cant know to help off the bat.
Did you tune it yet tho?
Old Apr 29, 2008 | 07:00 AM
express705's Avatar
yea it was tuned on friday.
Old Apr 29, 2008 | 09:22 AM
waijai's Avatar
i.love.gold
Get new fenderwell liners...they're not expensive at all.
Make sure it's hooked up correctly. How long has it been installed? You're not going to get a lot of oil immediately after install. Steel wool trick would work...i used a copper pot scrubber.
Check the threads and make sure there are 6-7 showing. You may have it set somewhere too loose to where it flutters. Check your intercooler piping to see if there is oil in there. Supercharger seals may need replacing.
4- ?????
5- exhaust leak
Smoke may be oil or something on your exhaust.
Welcome to the world of FI!
Old Apr 29, 2008 | 10:05 AM
express705's Avatar
i think ill drive my car into a tree if those seals are bad.
thats a 370 dollar job.
Old Apr 29, 2008 | 12:38 PM
Who tuned it? If i were you I'd throw in the towel and just take it a reputable shop and pay them to fix it and re tune it if anything...
Old Apr 29, 2008 | 12:46 PM
Dustin@StrafeAutomotive's Avatar
Really Needs a Life
sounds like you cut alot of corners.. that + FI =
Old Apr 29, 2008 | 12:52 PM
express705's Avatar
i didnt..
i had it tuned by a reputable shop and tuner.
only thing i did was install it, and you cant really mess that up. i fixed the oil pan leak, and thats the only thing thats been wrong on my part.
Old Apr 29, 2008 | 02:56 PM
2slo2bfurious's Avatar
How did you hook up your catch can? Maybe hooked it up wrong way and your getting blow by Or your pcv valve is being retarded?
Are you sure its white smoke, if it is, more than likely your still burning off that coolant rotfl Does it smell like oil? Or kinda "sweet" ?
Do you hear the bypass valve working at all? Maybe you should clean it up anyways since its a used kit.... dun circulate it and see if you hear it a "blow-off" noise. But I would just clean it if I were you.
Since you got it it tuned I really doubt it would be anything else serious, they probably would have caught it during tuning.
Old Apr 29, 2008 | 03:14 PM
GreenGoblin's Avatar
The goblin resurrection
I think it is the bi pass valve that is acting up, we will take it off and clean it
Old Apr 29, 2008 | 11:24 PM
express705's Avatar
bypass problem fixed. turns out my vac port was "overloaded" and there wasnt enough pressure, keeping it on 1 spot.
next problem, figure out where the oil is coming from
1- oil feed line
2- oil return line
3- seals (i hope not...)
Old May 2, 2008 | 02:39 AM
any updates?
Old May 2, 2008 | 06:59 AM
express705's Avatar
not until i get my car up on a lift.
seagrasser
May 3, 2022 09:43 AM
StreetStandard
Engine-Vendor
117
May 22, 2020 08:21 AM
n2fooz
Sep 4, 2015 07:46 PM
