What 3" exhaust to run with Twins?
Old May 7, 2008 | 06:21 AM
lostark374's Avatar
Arent Snails Slow?
the AAM is loud. very loud. but i like mine.
Old May 7, 2008 | 12:21 PM
str8dum1's Avatar
question is though, would you made more power on the EVott setup, using the APS?
does the EvoTT /new Ti-C exhaust have resonators in the middle like the Injen? The FI looks like all pipe to the mufflers. Just what I want.
My Injen resonators hang much lower than the frame do not want my new exhaust like that.
Old May 7, 2008 | 03:50 PM
BadBoy06's Avatar
But you still have the x box, and that does sit kinda low.
Old May 7, 2008 | 05:31 PM
TurboTim's Avatar
Another option:
http://www.speedforceracing.com/prod...g35exhaust.php
Tim
Old May 11, 2008 | 02:22 PM
drjonck's Avatar
Short Story: When Vinny Ten did my JWT TT installation I left on the Borla full set-up I had (swapping out the headers for the JWT manifolds, of course), because I loved the sound. Vinny said "If you want music, leave it on - if you want power, get the EVO TT". When I asked how much difference there was, he answered "25 to 30 more whp". I went for the Greddy, we put it back on the dyno and hp went from 381 to 408 @ the same 5600 rpm.
Old May 12, 2008 | 09:47 AM
BadBoy06's Avatar
Thanks for that insight. How do you like the sound with your setup?
Old May 12, 2008 | 09:55 PM
drjonck's Avatar
Well...the Borla was a purr leading into a growl. The Greddy is a growl that turns into a turbo-prop aircraft engine. There is no conversation possible at WOT above 3500 rpm. Cruising at a steady rpm above 60, the sound is always there, but music and conversation aren't impeded. Put your foot down though, and that ends the conversation (although you may be able to hear your passenger screaming).
Old May 13, 2008 | 12:49 AM
bullitproof's Avatar
Greddy tt. if you want a louder 3" exhaust with good flow, there are many options out there. i wanted an exhaust that i could hold a conversation with my girl at cruise and still have enough flow to make 600whp on pump(which i do) i had a 3" jic single on my aps single, but the noise was sooooo droning i waited 4 months to get the aps exhaust. it had the same flow but wayyyyy quieter. and above all, i like to sneak up on my victims, before i open the dumps and pounce!
Old May 13, 2008 | 10:05 AM
BadBoy06's Avatar
great info guys!^^^^^^
I want to have a conversation and not be droned out. It's alway nice to hear the radio or wife screaming to slow down
Another reason I'm waiting to hear the 3" Dominator
Old May 13, 2008 | 02:00 PM
Dan_K's Avatar
I would think an X or H pipe with the 3" TD would impede turbo flow compared to a straight through TD.
Old May 14, 2008 | 01:33 PM
BadBoy06's Avatar
That may be the case? I won't know until they (F/I) dyno the 3". I do remember reading on 350z that not only did it sound great but also flowed great as well.
Hmmmm the saga continues
Old Oct 19, 2010 | 02:35 PM
Nismo G's Avatar
If i run the fujitsubo single 3" exhaust...will i be able to support 500whp or will i need to change it out for better flow?
Old Oct 20, 2010 | 03:12 PM
jouvert00's Avatar
Actually it helps balance the exhaust pulses, i'm making 600+whp on a simple Stillen TD exhuast.
Old Oct 26, 2010 | 09:48 AM
rcdash's Avatar
Since this has been ressurected from the dead, let's add the Motordyne 3" TDX exhaust - lots of options for different mufflers/sounds from civil to loud.
Old Oct 29, 2010 | 10:58 PM
  #30
Sylvan lake V35's Avatar
Nice work on the 2 year old question we can put that to bed
