boost controller's
Old May 22, 2008 | 04:53 PM
GreenGoblin's Avatar
The goblin resurrection
boost controller's
What one are you using I am deciding between the greddy profec b and the one turboxs controls thru the utec. Any comments are appreciated.
Thanks
Danny
Old May 22, 2008 | 05:21 PM
BoostinJaxLR's Avatar
i use the HKS EVC6 and i like it, holds steady, has a bunch of features if you want them like 2 maps, shows an analog gauge and a numerical guage of how much boost, very clear display.
Old May 22, 2008 | 06:51 PM
FI'ed G's Avatar
You cant really compare an EBC and just the Utec BCS. Having said that, I do have the Utec BCS but I can't wait to switch to an EBC. Utec BCS does the job but it is not as good on holding boost as a good EBC.
Old May 22, 2008 | 07:11 PM
thank you any one else any more advise
Old May 22, 2008 | 09:18 PM
bullitproof's Avatar
i would do the evc6 or the blitz sbc-id. both are quality boost controllers. i check my boost regularly using the peak function on the defi guages. no boost creep since the blitz was installed in september. more expensive than the aforementioned boost controller setups, but sometimes you actually get what you pay for.
Old May 22, 2008 | 09:20 PM
EricIsKlumzyee's Avatar
I would go with NO BOOST CONTROLER.. use your ECU? or why do you need one? I cant think of a reason for MOST of us to use a boost controller.. its going to cause you to spike higher/more randomly as well.. also if you're in a stock motor why would you want something to let you turn up the boost.. our MPG isnt effected that bad when Turboed anyways "just a little higher is fine"
Old May 22, 2008 | 10:04 PM
sharif@forged's Avatar
Given the choice between the Profec spec B and the UTEC BCS controlled via UTEC...I would take the second choice. But my favorite stand alone boost controller is the HKS EVC6.
Old May 28, 2008 | 05:12 PM
ttrank's Avatar
Grocery getter
I have been very happy with my Greddy Profec B Spec II.
THMotorsports
Suspension-Vendor
257
Dec 18, 2018 05:43 PM
g.spot
May 9, 2016 10:54 PM
DEMoLITIoN
Audio/Video/Electronics
Apr 20, 2016 06:57 PM
markbilo
Sep 30, 2015 01:33 AM
