Oil circulation.. How does it work?
What do you mean? are you asking where in the oil system does the location for the turbo/supercharger oil feed lie in relation to the oil filter, bearing lubrication, cylinder head lube, etc?
I can't find a pick that shows the location of the oil pressure sending unit's location in the lubrication circuit. From its physical location, it seems like it might be before the oil filter. If so, that's not the best location to tap in for an oil feed for your FI unit. IUnfiltered oil going into my turbos.......
You've got me thinking.......................
.........I need to look into it. I have a couple extra pans sitting around.
![Icon43](https://g35driver.com/forums/images/smilies/icon43.gif)
Yeah we'll be using a spacer but on stock cars WITH turbos they have it set up where oil will flow through the turbo but seeing how our kits are 100% aftermarket. wouldnt a turbo thats lower then the oil pan have a hard time getting back into the pan? O.o no circulating oil = hot temps = nono
I dunno I know how the system works just having a hard time picturing it in my head ._. what pushes the flow? as quadcam mentioned the only place I can think of is tapped right after the filter and drianed into the turbo? O.o if so then it'll work?
lol iono just a random thought and no luck with search so thought i'd make a thread =P
lol... you'll actually blow out the turbo seals if it doesn't drain properly. if it's lower than the pan, you'll need a scavenger pump like the APS ST or the STS turbo kits have.
The turbo inlet needs oil PRESSURE. There is oil pressure from the oil sensor next to the filter. You have to 'T' off of that or get a sandwhich adapter where the oil filter is for the feed. The oil feed line is pressured which is pumped through the bearings in the turbo (inlet) and is drained out by GRAVITY (outlet) back to the oil pan.. in your case.. it has to be pumped back to the oil pan. pain in the a s s huh?
![Biggthumpup](https://g35driver.com/forums/images/smilies/biggthumpup.gif)
So you're pumping some unfiltered oil back into the pan huh >.> thats why they tell you to change your oil a lot sooner yea?
So how does the setup look if you're adding an oil cooler? you tap into that same point but you return it to the same return point so it passes through the filter? cant you do that with the turbo them? or like Tap into oil sensor.. goes into turbo.. then back out to cooler then into filter? would something like that work? ._.
So I want to guess theres a lot of APS ST smoking?
no matter what, the oil will pass through the filter one way or another.
for an oil cooler, you will need to add a sandwhich (with a thermostat) between the block and the oil filter. The adapter has two ports. The ports are usualy a size -6 or -8an with lines going to and from that sandwhich adapter. Port 1 from the sandwhich adapter goes into the oil cooler then the second line from the oil cooler goes into port 2 of the sandwhich adapter. really easy.
Don't worry about filtration. the oil gets cycled through the whole engine one way or another and will pass by the filter.
look at it this way, some small particles/debris are released from the moving engine internals......and this debris makes its way backinto the pan. then, the debris gets sucked up into the oil pump tube, through the pump and pushed right out into your oil feed line to your turbo!
now, before anyone jumps on this, someone needs to figure out the oil pressure sensors positioning in the oil circuit. the service manual doesn;t show it.
