Can I put GM Synchromesh in my 6mt?
Old Jun 25, 2008 | 09:35 PM
prelude2perfect's Avatar
I own a 98 honda prelude and gm's synchromesh works wonders on the tranny and Im hoping it can work with my wifes g35 to get rid of the notchy feel and grinds from 1st to 2nd and 2nd to 1st, anyone know if its compatible?
Old Jun 25, 2008 | 11:24 PM
avs007's Avatar
I don't know, but I know the Acura TL guys swear by the GM synchromesh in their 6MTs.
Old Jun 26, 2008 | 01:50 AM
spaceship's Avatar
I'd like to know the answer to this question too =)
Old Jun 26, 2008 | 01:55 AM
accordfreak's Avatar
no.. the oil needed is weighted. i had some in my honda and it worked wonders.. too bad our 6mt wouldn't go well with it. correct me if i'm wrong
Old Jun 26, 2008 | 02:00 AM
partyman66's Avatar
Honda Preludes and Acura TL's are front wheel drive cars... thus they have less notchy gearboxes due to the way the gear shifter is connected to the actual transmission... whereas our RWD G35's have the shifter lever going directly into the tranny. You feel more vibration and notchyness as a result. Our cars are still notchier than most RWD cars though.. but it's not really problematic or annoying, at least to me.
I wouldn't use synhromesh in our trannies. They're known for being very finicky transmissions about gear oil. I would just stick with the OEM dealer gear oil for the tranny since it's a very strange weight anyways(something like 85-90).
Old Jun 26, 2008 | 08:54 AM
geronimomoe's Avatar
Nissan requires the following:
"Genuine NISSAN Manual Transmission Fluid
(MTF) HQ Multi 75W-85 or API GL-4, Viscosity
SAE 75W-85 or 75W-90"
You could try:
1) Amsoil Synthetic Manual Transmission Gear Lub, which is 75w-90 API GL-4.
2) Redline MT-90, which is 75w-80 GL-4.
Don't know the side effects (if there are any). There shouldn't be but I can't say for sure since I don't have any personal experience with those 2 products in the G....
Good luck.
Old Jun 26, 2008 | 11:35 AM
dofu's Avatar
20 Year Member
The problem about your post is that Preludes, TLs, and Civics aren't made by GM... GM's synchromesh tranny fluid was originally made for cars like Vettes...
Old Jun 26, 2008 | 12:32 PM
partyman66's Avatar
What does that have to do with my post?
Old Jun 27, 2008 | 12:03 AM
absolutely nothing from what I see. Even though it was made for gm cars it is still perfectly compatible with honda transmissions and works wonders. I was hoping for the same with the g35 but I guess not
Old Jun 27, 2008 | 12:07 AM
You could try:
Good luck.
which is best?
Old Jun 27, 2008 | 03:41 AM
dofu's Avatar
20 Year Member
Well... since GM Synchromesh isn't made for Hondas to begin with, why not compare our synchromesh tranny to say, the synchromesh tranny made by GM instead of a Honda tranny?
Old Jun 27, 2008 | 07:02 AM
So you think it will work in the g35 tranny?
Old Jun 27, 2008 | 08:30 AM
Originally Posted by prelude2perfect
which is best?
Like I said, I don't have any personal experience with either product in the G. If it was me, I'd use the Amsoil since it meets the viscosity spec's required by Nissan.
However, I used the Redline MTL years ago in a car I had and it dramatically improved the shift feel.
Old Jun 27, 2008 | 01:05 PM
dofu's Avatar
20 Year Member
Honestly, no idea... but when people started suggesting using suynchromesh on a Honda tranny, the arguments why you shouldn't were pretty much exactly the same...
Old Jun 28, 2008 | 03:00 AM
hmmmm interesting
