Utec Mounting
Utec Mounting
Ok my last step in my FI adventure..... Where are you guys mounting your utecs? Pictures would be awsome looking for some inspiration for a clean install and fit. Yes I have searched and did not find anything good
Originally Posted by Meatshackle
Most mount it next to the ECU. You have to do some modifying of the ECU bracket.
+1
you need to use you brain to figure it out. TXS has no instructions for the G35......other than just make it fit.
it fits though. don't be afraid to cut brackets off of the UTEC and the stock ecu brakcet.
ya I had to cut my stock bracket in half and then cut all the tabs off the utec, there is also a stud on the firewall that I cut out
I did a quick search, found these 2 threads with some good info.
https://g35driver.com/forums/showthr...C+Installation
Good luck.
Good luck.
Claudiu
V36 Brakes, Suspension, Wheels & Tires
Mar 10, 2018 11:38 AM
