Something is very wrong with my car- Take a listen
Old Aug 5, 2008 | 10:58 AM
rockd's Avatar
yea, could be as minor as a stuck fuel injector... causing ur car to run on 5cyl. don't get worried just yet.
Old Aug 5, 2008 | 11:44 AM
Audible Mayhem's Avatar
if they are RC injectors, i would bet money thats what is wrong.
thats the reason that i wont use RCs. i have had to pull out 80% of the ones i have ever installed..
Old Aug 5, 2008 | 01:46 PM
rcdash's Avatar
If you have Cipher, you can turn a cylinder off, 1 at a time and try to see if you get to 1 that does not change the firing pattern. Then you know something is wrong with that cylinder.
Knock at idle is not likely (not possible?).
Old Aug 5, 2008 | 06:12 PM
sheplex02's Avatar
hahahhaha... i feel awesome.. im so happy that ppl agreed with me..
er.. um.. i mean..(cough)... sorry dont know what i just said but.. heh..
for real though, it prob is something really small like coil or injector.. so test them first before you rip the block apart..
Old Aug 5, 2008 | 07:02 PM
Jtrain's Avatar
It's the injectors that came with the greddy kit-- maybe I will give it to my shop to take a look at- I was for sure it was a motor build...
Though I still REALLY wanna do that in the near future anyway. It's so past due.
There is no clanking or smoke which is throwing me off- there is a rancid smell pure gas smell in the cabin though.
Old Aug 5, 2008 | 08:52 PM
Blackbird V35's Avatar
check to see if the spark plugs are all still intact
Old Aug 5, 2008 | 11:42 PM
Mr_pharmD's Avatar
I would get a compression and leak down test to determine if it is the motor.
Old Aug 5, 2008 | 11:48 PM
gEE805's Avatar
times two on the compression test.....check your water level and if its disappearing most likely you blew a head gasket which would be weird for the vq motors. so the sound is like a subie correct?
Old Aug 6, 2008 | 06:48 PM
Dsskyline's Avatar
I have a couple of ?s
what psi are you running? Did you up the boost more than what you are tuned for?
Did the sound start after or during a hard run? Do you have a data log of your run if so to see if you had a boost spike.
Is the sound the same when fully warmed up?
Any oil on the coilpacks (drenched) or broken SP tips?
Is there a milky residue on the oil cap when removed?
Any debris in your coolant?
Can you tell what side the knocking is coming from?
jack up the car and see if there are any leaks or something loose you can't see from above.
These are the things I checked when my engine went. Hopefully it's not something serious, but it does not sound good. It's happened to me twice I know the feeling.
These things you can check in your driveway
Jeremy me and my car will be paying you a visit in a couple of months when I move back to the east coast.
Old Aug 6, 2008 | 07:53 PM
rockd's Avatar
those are RC 440cc injectors... one of mine was stuck brand new out of the bag... fixed now, but it's your likely culprit.
Old Aug 8, 2008 | 12:06 AM
Jtrain's Avatar
It was 5 cyl because of a bad coil
Thanks for everyone attention- I really appreciate it!!
Old Aug 8, 2008 | 12:15 AM
GreenGoblin's Avatar
The goblin resurrection
thats a relief
Old Aug 8, 2008 | 10:14 AM
Jtrain's Avatar
LOL should I get ammo for the 12 gauge?
Old Aug 8, 2008 | 05:54 PM
sheplex02's Avatar
muahhahahahhaahaaa..... i did good.. how much is it costing to replace? cuz if its a bit.. upgrade to okada..
Old Aug 8, 2008 | 10:46 PM
  #30
Jtrain's Avatar
250$ with my shops big labor fees... 100$ in parts.
