What kind of Spark Plugs for Nitrous/Supercharger?
I know it should be 2 heat ranges cooler than the stock ones. Where is the best place to buy them and what brand/type? Anywhere on the net cheaper? Thanks a bunch.
B. Silver| Loaded to the "Brim"| 20" Iforged Rims - Flux| Pop-Charger | Z-Tube | Nismo Cosmetics | GroundGear Equipped | Borla TD | "Custom" Stereo - JL/Focal/Eclipse
Re: What kind of Spark Plugs for Nitrous/Supercharger?
I'm a firm believer in the ZEX spark plugs, designed specifically for forced induction...Check them out at their website, www.zex.com
"All the Power in the World resides in the Eyes..."
I had called Zex last week and they said they did not have any "yet" for the G35? Does anyone know of a good site to get some top of the line spark plugs from? Website links would be great. Zimbo, did you buy yours online?
From: Los Angeles, National Socialist Democratic Republic of Facistfornia
I'm using NGK Iridium Plugs 2 steps colder than stock.
100 shot of NOS Wet kit Single Fogger (For Now)
NGK Iridium BCPR7EIX-11 Stock number 5691
GOT STICKERS?
CPV35 Driven BY David K, VQ35DEN Tuned By DR CHARLES
...........NismoCPV-35
GOT STICKERS?
OH Yeah Gap them SMALL .20 -30 thousand of an Inch I have mine at .25
GOT STICKERS?
GOT STICKERS?
does dropping them one or two steps help NA cars?
2003.5 DP 5AT Sedan (E-thing but Nav)
14.2 @ 97.18
Injen CAI
10 Wire Hyper-Ground
Crawford Plenum (V4)
UR Crank Pulley
Polk ex-3500 Tweeter Upgrade/Shock Sensor/H-Liner Under Hood
14.2 @ 97.18
Injen CAI
UR Crank Pulley
Where did you purchase yours? Internet?
No. On NA cars going colder and smaller gaps will hurt your performance. The reason you go colder is to prevent detonation from the higher and hotter cylinder pressure and temp. Smaller gaps are to prevent your spark from 'blowing out', the more pressure in the cylinder the harder it is for the spark to jump the gap and in Forced Induction especially, the spark can get 'blown' away.
Andrew, We Miss and Love You! Peace!
Does anyone know someone that stocks these plugs or can get them? Internet Site/ Co. Name or phone number if possible? I would appreciate the lead. Copper would be great too as long as the heat range is 2deg. cooler. Help would be greatly appreciated. Thanks again.
Pep Boys or any Auto Parts house should be able to order them.......
Or Call NGK (Sales, Service, and Technical)
877-473-6767
GOT STICKERS?
877-473-6767
GOT STICKERS?
FINALLY!!
i confiremd the p/n with the dealer (17$ a plug!!) with NGK's 1-800 hotline, and they pointed me to a one step cooler plug p/n....
for ease of gapping (will need 0.30 to eliminate blow-out tendancies) i went with traditional tipped.....
oem = plfr5a-11
one step colder = plfr6a-11 (stock #7654)
i bought them online next, from www.ngk.com
good luck
<P ID="edit"><FONT class="small"><EM>Edited by esemes on 05/11/04 08:00 PM.</EM></FONT></P>
oem = plfr5a-11
good luck
I found a place in Garden Grove, CA. Stocks them.. $6.75 ea. Iridium IX - http://www.ngkiridium.com/
Thanks for everyone's help. Especially the part number for these plugs. Went 2 degrees colder.
B. Silver| Loaded 20" Iforged Rims - Flux| Pop-Charger | Z-Tube | Nismo Cosmetics | GroundingGear Equipped | Borla TD | "Custom" Stereo - JL/Focal/Clarion
Folks,
The best plug in the market are Denso Iridium Power. NGK was licensed by Denso to produce an Iridium plug using Denso technology. The original(Denso) is still better since it has a smaller tip therefore a more powerful spark.
If you want the best plug out there get Denso Iridium Power. They are expensive but are the best. Any Autozone carries them.
2004, blowing, g35, gap, iridium, kind, nitrous, pepboys, performance, plug, plugs, recommended, spark, supercharger, zex
