Anyone have a copy of the STS preloaded Utec maps?
Old Oct 3, 2008 | 12:26 AM
6MTFTW's Avatar
Does anyone have access to the maps and parameters that are preloaded with the STS 350Z kit? I contacted them about it and they quoted me $700 to send it back to them for reprogramming. I found that to be rather humorous. Needless to say, I'm not going that route. I just need a safe map to run until I get it over to my tuner.
Thanks,
Jerome
Old Oct 3, 2008 | 01:29 PM
FI'ed G's Avatar
Thanks,
Jerome
Go here http://www.turboxs.com/utec350zupdate.htm and download the TN 550cc map and parameters.. That should be close enough to let you drive your car to your tuner. Just make sure don't boost to much but that map is real conservative.
Old Oct 3, 2008 | 02:51 PM
express705's Avatar
cant you just load up that tn map and keep it in vac the whole time?
the map that you need to load should just be to run the injectors.
Old Oct 3, 2008 | 03:01 PM
Dustin@StrafeAutomotive's Avatar
Really Needs a Life
yeah run the tn 550cc map from turboxs... you'll be good to go. then have your tuner unleash the beast
Old Oct 3, 2008 | 05:16 PM
ttrank's Avatar
Grocery getter
Since you have a UTEC, just stay out of boost. The car will run off the ECU only while you drive down to UMS. There was another sedan guy who had the STS, look for him and PM him to see what he used for EM. Maybe he can send you the tune he used to help get Tony a head start.
Old Oct 3, 2008 | 06:25 PM
6MTFTW's Avatar
Haha. I'm actually buying the kit FROM that guy. And he was using the Greddy EManage Ultimate, which I opted against.
Looks like I'll be loading the TN 550cc map/parameters and limping it over there.
I can't wait!!!!!!
bigmike
Sep 17, 2015 01:58 PM
SilverG123
Engine - Electrical
Sep 4, 2015 01:12 PM
pdexta
Tuner & Dyno
Sep 2, 2015 01:03 PM
