widebands need help
widebands need help
i have a 2005 g35 I am about to install a procharger running 600cc injectors, utec, walbro fuel pump, ngk one step colder plugs, oil cooler, and kinetix hfc, dc headers, fast intentions exhaust, weapons r engine damper, obx oil catch can, and a plenum spacer and was wondering what everyone else is using for a/f been looking and dont know if i should run an a/f gauge or a wideband and if i should run 2 of them does anyone have this problem
Guest
Posts: n/a
Get yourself a 3 gauge a-pillar pod. That way you can have a wideband (I use AEM- only 1), boost, and fuel pressure, EGT, tranny temp (5AT mostly), etc. of your choice! You definately need a wideband at the least!
Get yourself a real good tune and be conservative at first. Welcome to the ProCharger realm
