Which Oil Catch Can to use with Vortech?
Old Oct 22, 2008 | 08:29 PM
terps's Avatar
weapon R? might work since it made to work with stock "air ram"
http://www.eracingworks.com/Weapon-R...1-p-39168.html
i like the concept but dont know if it actually works as well as Mr_pharmaD one
Old Oct 24, 2008 | 11:26 AM
LowUFO's Avatar
This looks like the one that Mr PharmD is using. http://www.eliteengineeringusa.com/Catch_Can.html I think I am going to order one for when I install my Vortech V3.
Ian
Old Oct 24, 2008 | 11:40 AM
GreenGoblin's Avatar
The goblin resurrection
Originally Posted by ttrank
I don't see a catch can on their site, did you get the breather?
Jaz mini breather 605-375-01 $42.50
1-800-525-8133 to order from Jaz
Old Oct 24, 2008 | 12:18 PM
ttrank's Avatar
Grocery getter
I have that one on my car. We cut it in half and made it into two parts; one half is a catch can and the other is a crank breather for the back side of the driver valve cover.
Old Dec 13, 2008 | 01:16 AM
Shakuya88's Avatar
Which catch can is the one that I usually se right in the front of the engine bay with 3 hoses to it?
Old Dec 20, 2008 | 05:02 PM
Modified Dave's Avatar
You mean like these?
If so, that is the blingtastic ARC catch can.
Old Dec 20, 2008 | 05:47 PM
Shakuya88's Avatar
Yeah, that one (^^^) Will that work with the vortech?
Old Dec 20, 2008 | 07:05 PM
If you look at this pic from Vortech's website, I'm thinking it'd take a bit of creativity to route the hose to the driver's side past the main serpentine belt, but I'm sure it could be done (and probably has been...hopefully someone on this forum with that setup will chime in).
Old Dec 20, 2008 | 08:44 PM
Mr_pharmD's Avatar
I would just hook a breather the driverside bc no much oil comes out of that one. The passenger pcv has the most oil.
Old Feb 24, 2012 | 11:36 PM
joeb1983's Avatar
G35
I found a AGP baffled oil catch can made for the SRT4 on eBay for $20. Worked out perfectly in my opinion. I drain whatever is in there every few oil changes. Its not much. Maybe a teaspoon...
f22raptor
Mar 18, 2016 08:50 AM
prinny
Nov 22, 2015 11:07 PM
mbe32
Nov 13, 2015 11:09 PM
9tray turbo
Sep 29, 2015 10:22 PM
