Vortech Build Suggestions
Old Oct 28, 2008 | 03:38 AM
sentry65's Avatar
why do a compression test and leakdown test if you're just going to build the motor anyway?
I agree that 8.5 compression is way too low for the vortech. Get at least 9:1 if not higher IMO
...honestly I wouldn't spend the money on building the engine from the start. The stock engine can hold quite a bit of vortech power as it is.
Originally Posted by Asad_A203
There is a g35 5AT in the city putting down 600-700 RWHP with a Vortech and a stroker kit and I believe he only had a valve body and a cooler. Not sure though...
uuhhhhhh, that's probably not a VQ 6 cylinder engine...
Old Oct 28, 2008 | 08:59 AM
jonnylaw's Avatar
Old Oct 28, 2008 | 11:35 AM
Mr_pharmD's Avatar
i'm with jonnylaw on this... BS with 600+ whp. He says he's pushing 22psi with the 2.87 pulley and T trim which is impossible (unless he has a cog setup). I would love to see his pulley setup bc i'm sure it's slipping like crazy. Also he went gauge happy but that intercooler does look nice.
Old Oct 28, 2008 | 12:21 PM
str8dum1's Avatar
ya no way on 600rwhp. maybe 600 backcalculated at the crank including blower loses. Then sure 600.
no way at 22 psi unless he's got a 1" exhaust. Its a show car with "show car" numbers.
If you wanna make power with a built motor, run at least 10.0:1 compression. You only make good boost at the top end, so low compression like that would be junk when not in the hi rpms. Its not like a turbo that runs max boost after its spooled, in that case you can run lower compression.
Old Oct 28, 2008 | 12:35 PM
Mr_pharmD's Avatar
hey str8dum, u ever get the 34tooth cog pulley I sent ya? Would love to get a + feedback
Old Oct 28, 2008 | 01:22 PM
minus500's Avatar
.........waiting for Booger to come in. 460whp through a 5AT sounds pretty good!!!
Old Oct 28, 2008 | 03:27 PM
Asad_A203's Avatar
Originally Posted by jonnylaw
You guys can ask Mike at AAM what the vehicle is capable of; he built it. That is just what I have heard so it might be wrong. I don't want any **** flying because I didn't check so don't quote me on that; haha.
Old Oct 28, 2008 | 03:40 PM
Asad_A203's Avatar
I read that on alot of builds being done so this is not necessary since the pistons and rods are being replaced; correct?
I am just concerned about the rods snapping which seems to be pretty variable. Would a lower compression ratio benefit a turbo kit better than NA/SC application?
I am also considering a Turbonetics ST if it can deliver more power than the Vortech.
As you can see; I still got more research ahead of me but thanks for the input/advice so far.
Old Oct 28, 2008 | 04:57 PM
Mr_pharmD's Avatar
u need to determine what u want to go. Turbos and sc have different builds so u need to figure how u want your pw curve to look like. Do u want massive hp and tq or a linear style pw.
Old Oct 29, 2008 | 01:50 AM
Asad_A203's Avatar
I was initially going with the Vortech without the built block due to the linear power curve and how it would not hurt the tranny or block but I have decided it is better to build the car (as everyone seems to say thay they should've built their engine when they blow the stock block) and then go FI. The Vortech also seems to be the most reliable in the sense of it being much more dependable as a Daily Driver versus a turbo. I love the way a turbo operates and delivers the power versus a supercharger but this is all at the expense of reliability. I am still weighing out reliability as opposed to power...
Primarily I have not heard too much on the TN ST kit but can you guys fill me in on the reliability factor and the ability of this kit compared to the Vortech? I know the TN requires you to heatwrap the AC lines around it, relocate the AC lines and has higher temperatures than most turbo kits. I am not sure if the FAQ is old but it mentions 500 RWHP is achievable under the correct tune.
I am going to research more on the TN ST and get back to the topic on hand.
Old Oct 29, 2008 | 02:02 AM
sentry65's Avatar
IMO I'd still ride the stock block for everything it's worth.
Even a built engine can die over stupid crap - injector going bad, sensor malfunctioning, etc
Old Oct 30, 2008 | 05:35 PM
Asad_A203's Avatar
True; I guess it is just about everything I have been reading recently. I would feel pretty good about boosting a G with a built engine though.
KruZZe
Feb 27, 2023 05:04 PM
g.spot
May 9, 2016 10:54 PM
andrewvk
Engine - Complete Motors
32
Apr 7, 2016 01:39 PM
9tray turbo
Sep 29, 2015 10:22 PM
Jay123
Sep 28, 2015 08:42 PM
