Fuel Pump noise
Old Nov 8, 2008 | 07:03 PM
jonnylaw's Avatar
Fuel Pump noise
For those with a Walbro pump/and or return fuel system, do you hear a "hum" coming from the back?
I was told high performance fuel systems can be louder. The "hum" is fairly pronounced when at idle, but not noticeable when driving (b/c of engine/exhaust noise).
Any way to lessen the "hum"? dynamat maybe?
Old Nov 8, 2008 | 07:08 PM
express705's Avatar
normal...
although my car is so loud, dynamat isnt going to do ****.
Old Nov 8, 2008 | 07:12 PM
jonnylaw's Avatar
Originally Posted by express705
normal...
glad it is a "normal" issue. Thx for your input! lol, loud can be nice!
Old Nov 8, 2008 | 07:20 PM
inneedof's Avatar
They are nick named whinbro's
Old Nov 8, 2008 | 10:02 PM
ttrank's Avatar
Grocery getter
When my back seat is in I can't hear mine at all
Old Nov 9, 2008 | 12:07 AM
FI'ed G's Avatar
me too.. Sometimes I even wonder if I have the walbro back there...
Old Nov 9, 2008 | 03:49 AM
urban's Avatar
I can't even here mine either, I even tried to listen for it.
Old Nov 9, 2008 | 10:07 AM
Q45tech's Avatar
As the pump wears from dirty gasoline and ethanol/water corrodes commutator and pump brushes, the pump rpm slows down and down and the pitch becomes audible. Important to frequently change gasoline filters to minimize wear and to clean tank of accumulated microscopic wear particles that settle and concentrate near pump intake sock.
Oem sound deadening IS TUNED for a new pump so that any wear becomes noticeable and leads to pump replacement befor failure.
The newer returnless system only pump the gasoline as used so they have to pump 1/5- 1/15 of the gallons per hour that return line system deal with, should have a longer life except the pressure has increased from 34/44 to 51-60 psi.
Old Nov 9, 2008 | 02:32 PM
jonnylaw's Avatar
But the sound deadening is designed for a OEM fuel pump and not a high performance pump like the Walbro correct?
B/c I have heard my fuel system since the day I got it.
This explanation seems plausible to me:
Originally Posted by punish_her
Fuel density and volume changes with tempratures. The sligtly denser fuel will cause a slightly higher strain on the pump. Not too much, but probably enough to change the pitch sligtly diffrent than what your use to and bringing it to your attention. It's not that it may be lounder but probably at a diffrent resinanace than your use to.
Hell I notice that even in Hawaii. In the summers when its warmer all the time its has a slightly lower pitch, not much strain. In the winters when its a little cooler in the morning and warmer in the afternoon I can hear the pump in the AM and the noise goes away closer to mid day.
IMHO, Such is life with a high volume fuel pump.
Old Nov 9, 2008 | 03:24 PM
ttrank's Avatar
Grocery getter
I am installing an AAM surge tank and bosch pump setup. The W255 will supply the surge tank with no backpressure. I'll see if it's still as quiet.
Old Nov 9, 2008 | 04:08 PM
thom000001's Avatar
SP Triple pump hear....can't hear the pump(s)
Old Nov 9, 2008 | 04:36 PM
superchargedg's Avatar
I have heard mine from day one....but it dosent bother me at all.
Old Nov 17, 2008 | 10:31 AM
SnyperZ's Avatar
Do you have the factory sound mat over the pump? It was much quieter with the mat.
Dallsinghjr1
Sep 17, 2023 11:25 AM
Marlin84
Apr 1, 2020 12:52 PM
g.spot
May 9, 2016 10:54 PM
dcsbh1
Oct 1, 2015 03:15 PM
Hogbone
Sep 28, 2015 06:44 PM
