need help b4 i go raise hell
Originally Posted by Canadian
I don't think its normal to throw a code... I never threw a code for over 13k miles boosted until I put on test pipes. Now obviously I throw a code, but other than that I'm good.
If you have a stand-alone, there are often thrown codes as a result (that do not indicate failure/damage). Also, different ecu's from different model years, mayt react differently to stand-alone ems's and boost.
OP if you find out your tune/setup is ok and want to eliminate the cel, see:
http://gtmotorsports.com/product.php...cat=260&page=1
^He doesn't have a standalone so I fail to see how your post is relevant. With a utec you shouldn't throw a code. If my split second box can go with no codes, so should a utec.
Originally Posted by jonnylaw
Not necessatily true.
Originally Posted by Mr_pharmD
Why would a standalone throw codes when a piggyback doesnt? I have one of the cheapest piggyback out there, the EU and I didn't throw any codes... but a $2K Kpro will for no reason???
well im pretty sure i have a small boost leak in my plenum spacer and i just noticed that my cog belt was missing cogs already... belt looks like ****.... so i guess ill be replacing it already..
Guest
Posts: n/a
aligned correctly.. how shouldthey be aligned? 1 is on he bracket and 1 is on the blower and then tension 1.. they are all in a fixed position arent they, well except for tension and that goes where ever is tight enough
he means that you should be able to take a straight edge and touch flush all the pulleys. If not they are not aligned.
if you are breaking cog teeth, your belt is wayy too tight.
yeah thats what i was thinking when i felt it b4 i took it off... it was way too tight.. i couldnt flip it at all... i had to order a new today... should be here at 9am... got 2 so now i got a spare.... the belt almost looks like it was starting to seperate, also looks like maybe oil got on it and dried... i have the belt off now and i can rip teeth off very easy with my fingers..
ill check to make sure they are all straight... but if they wernt straight wouldnt i get a noise or belt slippage?
