G35’s with Vortech Supercharger
Old Jun 1, 2004 | 08:22 AM
DFWG35's Avatar
I just had the Vortech system installed on my 2003 G35c and I have some questions.
1.What is the highest pulley/PSI you have tried? I am at 8psi considering 10psi
2.What spark plugs are you using?
3.Has anyone preformed the oil change requirements? I.e. the Vortech oil spray line.
4.Has anyone had motor issues? Pistons / Valve / lifters due to HP increase.
Old Jun 1, 2004 | 09:31 AM
booger's Avatar
Re: G35’s with Vortech Supercharger
I have the Vortech....379whp....8psi pully...I step colder Iridium plugs....Plan on letting the shop pull the blower twice a year to clean spray nozzle and clean air filter . No problems at all with motor
Couldnt afford it when young...gonna play when Im old
Old Jun 1, 2004 | 03:44 PM
gdupg35's Avatar
I'm just assuming this is the case...."379whp" means 379 wheel horse power.
Old Jun 1, 2004 | 03:54 PM
booger's Avatar
Yes 379 to the wheels. I have tuned the A/f ratio to 11.8 .....12.2 to 1 .Havent touched the timing yet...still at Vortech's settings .I think the dyno guy said 440hp to the crank
Old Jun 1, 2004 | 05:31 PM
Profile4's Avatar
379 is impressive, wat other mods do u have?
04 DG/G/6MT/Premium/Nav/Clear Bra
Bone Stock...to be continued...
"You kill mah brodah, now I kill you!" - some old kung-fu flick
Old Jun 1, 2004 | 09:50 PM
booger's Avatar
click on my name and see the pics and read the mods
Old Jun 2, 2004 | 12:59 PM
booger's Avatar
With the smaller pully you may need to add larger injectors [dont know] I know the ATI guys had to when they went to smaller pully
Couldnt afford it when young...gonna play when Im old<P ID="edit"><FONT class="small"><EM>Edited by booger on 06/02/04 10:01 AM.</EM></FONT></P>
Old Jun 3, 2004 | 12:38 AM
subrobo's Avatar
I really wanna ask few nebie questionplz kindly answer)
1. How much did you guys pay for the vortech supercharger?
2. other the the supercharger from vortech, what other mods do i need to support the HP gain?
3. Will vortech supercharger fit into my sedan it i got nissmo CAI?
Old Sep 15, 2010 | 08:22 AM
mjd240's Avatar
I have a Vortech V-3 G35 coupe. It is very difficult to get out and replace the cone air filter. Any tips/suggestions? Some say slide it down around the wheel well. When I look, it does not seem possible with out damaging the filter.
Old Sep 15, 2010 | 07:33 PM
bigc's Avatar
Wings Nation
the filter is gonna get deformed a little, there's no getting around that. if you have skinny fingers you can work it out/in by sliding along the core support, but your best bet is to remove the driver side fender liner and go at it from below.
Old Sep 16, 2010 | 05:15 AM
HotRodG35's Avatar
Thats not true. If you trim top of radiator support and use a large screwdriver with shop rag protecting tip gently bend AC supply line to condenser out of way the filter drops in with no deformation.
1. I have used a 2.87 pulley to 12 PSI switching to 2.75 after built motor tuned.
2. 1 step colder NGK iridium.
3. Never had issues with spray line. 5.5 years and 32K with Vortech
4. Do not change pulley to smaller diameter without a retune. I changed to a 3.12 did not retune immediately and ended cracking rings over short period of time.
Old Sep 16, 2010 | 10:51 AM
bigc's Avatar
Wings Nation
most people would rather not go hacking into their core support to slide in a filter that can easily be installed without doing so. to each his own i guess
Old Sep 16, 2010 | 11:16 AM
HotRodG35's Avatar
I didn't "HACK UP" my radiator support. It was carefully cut and radiused. Beats the hell out of deforming the filter into a twisted beer can .
The filter is not easily installed in a G35, remember the instructions have the filter pushed up to radiator support and than mount supercharger.
I was providing an alternative that allows easy installation without deforming filter.
Old Sep 16, 2010 | 11:30 AM
bigc's Avatar
Wings Nation
the filter gets deformed a little (as stated above). if someone is crushing their filter until it looks like a twisted beer then they probably shouldn't be cutting into their core support. the filter goes on pretty easy if you go through the wheel well.
Old Sep 16, 2010 | 12:20 PM
HotRodG35's Avatar
Real easy, let me see jack up car, remove wheel and than remove fender liner.
My method gently pry on condenser line and remove filter (after clamp loosened and PCV hose disconnected)
I'm constantly making improvements and cant begin to count number of times filter was removed over the last 70 months of owning a Vortech.
Alternate method which you did too was the remote CAI.
I briefly used the CAI setup but decided to clean up engine bay and relocated oil catch tank from top of radiator support to frame rail.
So I guess to each his own
