New Haltech dual channel wideband
Old Dec 9, 2008 | 11:26 AM
Hal@IP's Avatar
We just received our first batch of the new Haltech Wideband controllers, capable of controlling dual sensors. Great development went into making these wideband controllers the best on the market, without all of the errors and failures commonly found in competing o2 controllers. It is a small and compact package that is very simple to install with just four wires (power, ground, sensor output and dimmer if needed). This minimizes cluttered, bulky installations so typical with dual Innovates.
This is a standalone wideband controller that can be used with any ems, or just with a gauge. The controller has 0-5v AFR outputs (1 or 2 outputs depending on number of sensors). Also, it works excellent in conjunction with the Haltech Platinum PNP EMS, which has dual wideband inputs and can make bank-specific fuel corrections based on dual o2 sensors. We are able to pre-wire the EMS harness making it completely plug & play when purchased with a Platinum EMS.
Pricing is very affordable - as low as $236 for a single sensor setup, and as high as $379 with dual sensors and a gauge. This makes it a better value than anything else on the market.
Haltech AFR in stock at 350Zmod.com
g.spot
May 9, 2016 10:54 PM
Red G Coupe
Tuner & Dyno
Jan 14, 2016 01:13 AM
BfloG35
Audio/Video/Electronics
Oct 16, 2015 05:22 PM
9tray turbo
Sep 29, 2015 10:22 PM
Red G Coupe
Video Share
Sep 28, 2015 06:29 PM
