need help or advise
Old Dec 10, 2008 | 12:04 PM
v35's Avatar
v35
need help or advise
let me go ahead and tell you guys what happened... car is 03 G with PE tt running w/9psi, with utec management... fuel system is all stock but injectors are 380cc that comes with TT kit... car was doing 60-65 on freeway.. and all of sudden car got shut off... and it wont start back at all... i was concerned if engine blew.. but seems like engine is not blown... what could cause this thing to happen..???
Old Dec 10, 2008 | 05:45 PM
booger's Avatar
Could be a hundred things . You are not giving us enough info , and sounds like you are unable to do so . Take it to the shop that did the install . They can go thru it and find out the problem . Its probably nothing to bad .
Old Dec 10, 2008 | 05:59 PM
v35's Avatar
v35
gas was full( had premium), car was running smooth and all of sudden it got shut off and when i try to start it back up , car tries to crank but it wont start.... no sign of oil leak or broken engin part, checked oil level and level was good....
Old Dec 10, 2008 | 06:34 PM
superchargedg's Avatar
Get the computer scanned and see if any codes come up as i would bet the crank sensor died.
Old Dec 11, 2008 | 11:16 AM
v35's Avatar
v35
i will try to see if thats the case... hopefully its a minor problem...
Old Dec 11, 2008 | 01:54 PM
G37Rider92649's Avatar
Does it crank crank? Or does it just click and everythings dead? Did you see any smoke? No oil spills right? You know it could be that you blew your motor too right, not trying to scare you but that's the worst case scenario of course.
Old Dec 11, 2008 | 02:26 PM
escobar929's Avatar
most likely is the crank sensor, lots of people have had that happend to
Old Dec 11, 2008 | 06:19 PM
v35's Avatar
v35
i hope its not the motor, cars not leaking any oils even now, car does try to crank but it wont start... had replaced spark plugs not to long ago, when i installed turbo kits, its been always running with 93 oct gas, has about 8k to 9k after turbo installation... car always cranked okay, drove fine until now...
Old Dec 15, 2008 | 11:32 AM
XKR's Avatar
XKR
Stop trying to start the car.. Like Booger said...take it and have it checked out. The car may have stalled to prevent you from causing damage
Old Dec 15, 2008 | 07:48 PM
v35's Avatar
v35
thanks guys~ taking to a shop this week
Old Jan 13, 2009 | 10:34 AM
amf25's Avatar
did you find the problem? post an update
Old Jan 13, 2009 | 04:40 PM
djamps's Avatar
Sounds like an electrical problem. I doubt it's major ($$$ wise) unless an ECU died. Hopefully just a loose connection...
esotericrider
Feb 14, 2022 07:19 AM
Dmill86
Sep 6, 2015 08:14 PM
bjo16
Aug 4, 2015 09:52 AM
CJay
Aug 1, 2015 03:57 AM
