Where did u place your HKS AFK and NAVI???
Old Dec 21, 2008 | 09:00 PM
Mr_pharmD's Avatar
Okay, where did u guys place these bad boys? I'm not sure if I like the position where I put my AFK at. It's show and tell now so please let me know where u have them. Thanks.
Old Dec 21, 2008 | 09:51 PM
G37Rider92649's Avatar
I put mine where my stock navi is suppose to be.
Old Dec 21, 2008 | 10:27 PM
XKR's Avatar
XKR
You can see everythng here .....www.cardomain.com/ride/808731
Old Dec 22, 2008 | 12:12 AM
Mr_pharmD's Avatar
omg your setup is insane. I love those bbk.
Old Dec 22, 2008 | 08:04 AM
XKR's Avatar
XKR
Thank you
Old Dec 22, 2008 | 08:26 AM
GreenGoblin's Avatar
The goblin resurrection
Yes Mike your car is insane o
Old Dec 22, 2008 | 09:17 AM
jonnylaw's Avatar
If you had the Camp2, you wouldn't need to have guages all over the place
Old Dec 22, 2008 | 10:23 AM
XKR's Avatar
XKR
Thank you,,
Very true...The Camp2 can display anything you want in many different ways...ie: temp/pressure...oil,fuel,air,boost,volts,egt,water,...t oo many to list..
Old Dec 22, 2008 | 11:01 AM
I wish I would have got the camp 2 when I was building my car instead of after.
Old Dec 22, 2008 | 11:58 AM
TTG35forT's Avatar
Here is my AFK, turbo timer and EVC. My Navigator is where the ashtray used to be. (I forgot to take a picture of it). I spliced the cable as shown in the drawing below so that I can move it to the lower left portion of the windshield when I am on the track at HPDS.
The RJ-11 Connectors and Cable are standard telephone connectors and cable. It is working great.
*** NOTE *** DO NOT UNDER ANY CIRCUMSTANCES CRIMP THE RJ-11 CONNECTORS ONTO THE CABLE WHEN THE CABLE IS PLUGGED INTO THE F-CON!!!
One of my connectors was not fully crimped, so I went back and re-crimped it, but forgot to unplug it from the F-CON. The RJ-11 crimper has a single metal bar that crimps all of the pins simultaneously, and it caught my F-CON V Pro on fire. (The internal ribbon cable is insulated with paper ).
Japtrix and Garret at HKS were really cool. They gave me a new F-CON V Pro at a deep discount (I think at cost). Nonetheless, the damage does not look to bad and I may be able to fix the old one and use it as a backup, or for my next project.
After I fried my F-CON, John was really cool and let me borrow his so that I could make Homestead the next day. That night turned out to be a string of bad luck, however. We re-set his jumpers per the manual to configure his F-CON to work in my VQ-35DE, and uploaded my F-CON files. WOT shifting worked great with my F-CON, but when I tried it with John's, the rev limiter never kicked in and I pegged my tach. Now my car is back at Japtrix with a ticking sound. Hopefully it is only the valve train, but we don't know yet. Roger is going to try to get the motor out this week to look at it. I guess I was not meant to make it to Homestead.
For now on, I am going to fully test everything with baby steps before just going out there and hammering it hard.
On a good note, we got 609 hp and over 600 ft-lb of torque (actual measurements) on the dyno with 93 octane (this was before I tried my WOT shifting stunt). The temperature was somewhere in the mid-70's. With weather correction, my hp was 603 hp. The boost was 17 1/2 psi.
Last time my hp was in the 550's at 13 1/2 psi, but it was hot and it weather corrected up to 584 hp. It may seem like I did not get much for the extra 4 psi of boost, but since it was hot last time (and hence there was less air/fuel going into the combustion chambers), we were able to run more advanced timing. With the cooler weather (and thus more air/fuel going into the motor), we had to pull the timing back to keep it from pinging on 93 octane.
Old Dec 28, 2008 | 05:40 PM
TTG35forT's Avatar
Within the next couple of weeks I'm going to look into recessing the AFK, EVC and TURBO TIMER displays into the dash.
Old Dec 28, 2008 | 05:58 PM
urban's Avatar
My Navi is in the ashtray.
Old Dec 28, 2008 | 06:57 PM
Mr_pharmD's Avatar
Nice, I wanted to put it there too but it didnt seem to fit in the 05.
My 2nd option was this:
Old Dec 28, 2008 | 10:05 PM
TTG35forT's Avatar
I had to do a little bit of filing on the bottom side of the ashtray opening to get mine to fit, but it looks pretty much the same as Pharm_Ds.
Old Dec 28, 2008 | 10:26 PM
urban's Avatar
[QUOTE=Mr_pharmD;3756423]Nice, I wanted to put it there too but it didnt seem to fit in the 05.
I am putting the ashtray cover back on so it will have the sleeper look I want
