Trans question and 1000hp Turbo car....
Old Jan 3, 2009 | 10:50 AM
rlwjr1's Avatar
I was reading about that 1000hp G in the latest Turbo Magazine and I have a question. In the list of mods there is nothing mentioned about his trans. How much HP can the stock tranny handle before grenading??
Old Jan 3, 2009 | 12:08 PM
mIKE's Avatar
PM me if you'd like to get in contact with Tom's tuner.
I am going to warn you that Tom daily drives a (modded) M5 and owns two G35's... attaining this level of power is NOT an easy task.
Old Jan 3, 2009 | 12:37 PM
serturbo's Avatar
Any links or info on g35driver about the car? Searched but no cigar. Thanks
Old Jan 3, 2009 | 12:53 PM
Hotdawwgman's Avatar
PM mike... or Tom... Answers arent to far away!
Old Jan 3, 2009 | 08:03 PM
str8dum1's Avatar
the injected 1000 hp G35 (assume thats the one you are talkina bout) runs on the stock 6 speed with upgraded axles AFAIK
Old Jan 4, 2009 | 10:28 PM
thom000001's Avatar
I've make 900hp (did 769rwhp not quite revving out) spent some time at that power, spend more time at bout 800hp (700rwhp) with no problems.
Sound Performance is also running a stock 6 speed with dss axles in their 1033rwhp Z that went 9.35@158
Old Jan 4, 2009 | 10:41 PM
G U LATER's Avatar
Is there any vids of the z.
Old Jan 4, 2009 | 10:45 PM
thom000001's Avatar
Yup
<param name="movie" value="http://www.fquick.com/videos/fquickplayer.swf?file=7455&autoStart=false"></param><param name="wmode" value="transparent"></param><embed src="http://www.fquick.com/videos/fquickplayer.swf?file=7455&autoStart=false" type="application/x-shockwave-flash" width="400" height="330"></embed>
Old Jan 4, 2009 | 10:51 PM
MyocyteX's Avatar
Wow......
Shakuya88's Avatar
DAMN!...just DAMN!
Old Jan 4, 2009 | 10:58 PM
on3_Lo35's Avatar
i just shatted in my pants...
Old Jan 5, 2009 | 12:18 AM
SlideFox's Avatar
Intense's G made 906rwhp with a stock trans, and ATS Triple Carbon....
Chris's (mazzoo) 350Z that made 1013rwhp is a stock trans with a tilton I believe.
Both Cars are running DSS axles
Old Jan 5, 2009 | 10:57 AM
thom000001's Avatar
The axles are the mucho-weak point.
Old Jan 5, 2009 | 11:19 AM
kaisar's Avatar
The G that was in Turbo Mag has a triple-plate clutch , lightweight flywheel , two way limited slip differential and converted his final drive from a automatic...
Old Jan 5, 2009 | 11:28 AM
thom000001's Avatar
I think every multi-disk clutch comes with a LWFW. To hold that much power you will have to go to a multi-disk clutch.
The diff is personal prefference as far as what limited slip you want to go with. And if they wanted the 3.3FD then yes you go with a auto diff. Its a direct swap. Pretty much anyone over 500rwhp will tell you the auto diff is a great idea (unless you are revving to 9Krpm and only one car is doing that)
All normal stuff.
Tom
