APS TT Tuner Kit(D.I.Y install) + Haltech = The Injected Experience **56K warning**
Old Apr 22, 2009 | 04:36 PM
  #31
tiguy99's Avatar
What do you have planned for round? Will it also require you drop the motor again?
Old Apr 22, 2009 | 04:44 PM
  #32
D-tuned's Avatar
Big motor, upgraded turbos,new multi-disk clutch and a few accessories
Old Apr 22, 2009 | 06:35 PM
  #33
superchargedg's Avatar
I still cant figure out those dyno numbers cause a dd should be lower then a dj.Mine on a dd was 389rwhp and 391rwt but on a dj it was 412rwhp and 406rwt.
Old Oct 4, 2009 | 01:38 AM
  #34
tiguy99's Avatar
Any updates on this Epic thread? Just curious to see what's happened since the last post
Old Oct 4, 2009 | 10:53 AM
  #35
D-tuned's Avatar
Car is running the same it was the day it was tuned, GREAT!!! I've brought some accessories preparing for the motor build. I"m current on deployment and everything will be done once I get back. I'm hoping to have everything done in time for ZdayZ. I will make a new thread or update this one once completed.
Old Oct 4, 2009 | 06:30 PM
  #36
tiguy99's Avatar
Nice! Now that's an Epic win
Old Oct 8, 2009 | 11:09 AM
  #37
rcdash's Avatar
Except for being sold a TT kit that will not work on a built motor... I wouldn't worry too much about the difference in numbers. Heat soak makes a big difference, temp corrections in the tune, atmospheric changes, intrinsic differences in the dynos, etc all add to the long list of variables.
Old Oct 8, 2009 | 04:18 PM
  #38
D-tuned's Avatar
turbo's and intercooler are getting upgraded when I pull the motor
Old Oct 8, 2009 | 05:13 PM
  #39
rcdash's Avatar
Blouch has some good deals and experience with the APS turbos.
Old Oct 8, 2009 | 06:45 PM
  #40
D-tuned's Avatar
yeah, I've been following cass007 thread. I have something bigger in mind
Old Oct 8, 2009 | 09:48 PM
  #41
rcdash's Avatar
You will lose area under the curve if you shift the powerband too far to the right, beyond where you can actually use it. Just something to keep in mind. The squirrel calculator is a very nice site for seeing how different turbos will perform for your engine.
http://www.squirrelpf.com/turbocalc/
Tolboothwilley™
Exterior-Vendor
Jul 28, 2016 12:42 AM
madmax032
Drivetrain
Jan 18, 2016 10:41 AM
justgotg35
Jul 19, 2015 12:33 PM
Chattzx
Jul 17, 2015 11:23 AM
